Wheel spacers and stud kit...anyone run this one?
01-27-2021, 12:54 PM | #1 |
2002
Rep 3,731
Looking at installing some wheel spacers on my 07' 335i. I found several kits on amazon that look like they would work. Anyone ran a kit like this Good quality, or total junk?
https://www.amazon.com/Complete-Stag...7J5XM3B3&psc=1
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
01-29-2021, 02:00 AM | #2 |
1368
Rep 1,532
I'm so wary of Amazon car parts I would DEFINITELY not risk it on something as crucial as these. If you're chasing down vibrations from a badly machined spacer or god forbid lose a wheel because the seller lied about the bolt hardness rating, the ~$100 you're saving on these over a proven vendor such as Motorsport Hardware isn't gonna look too good anymore.
The linked product has 2 ratings and 0 written reviews, so to me those ratings mean nothing--chances the vendor contacted someone to leave a rating are very high. This combined with the fact that every car part I've seen on Amazon has been complete trash makes me think it's just not worth the risk. |
Antetokounmpo1551.50 |
01-29-2021, 12:35 PM | #3 |
2002
Rep 3,731
I did check on the grade of steed that's used for the studs...and it's a 10.9, same as all of the "better known" brands out there. Not saying that alone makes the parts "quality" , but at least they aren't made out of some cheap china mild steel or something.
02-03-2021, 07:00 AM | #5 |
2002
Rep 3,731
Well, I got that Venom brand spacer and stud kit in. The quality of the spacers and studs is actually really nice. The studs have nice and clean threads, and the spacers are machined very nice.
They say that the studs are grade 10.9.....but I'm not really sure if there is any way to tell for sure.
02-03-2021, 12:05 PM | #7 | |
1368
Rep 1,532
I'm not really sure if there is any way to tell for sure. This ^ is my main concern. They can say it's made of just about anything...does that make it true, or even likely to be true? Who knows |
02-03-2021, 02:43 PM | #8 |
2002
Rep 3,731
02-03-2021, 06:18 PM | #9 |
1691
Rep 3,652
02-03-2021, 07:23 PM | #10 |
1368
Rep 1,532
02-03-2021, 09:02 PM | #11 | |
2002
Rep 3,731
Would you buy a used serpentine belt? Used idler pulley? |
02-04-2021, 12:54 PM | #12 | |
1368
Rep 1,532
These two items you listed are wear items, wheel bolts/studs are not. |
02-04-2021, 05:27 PM | #13 | |
2002
Rep 3,731
02-04-2021, 06:57 PM | #14 | |
1368
Rep 1,532
-everyone in the thread had either dedicated track cars or tracked their cars heavily. Based on your past posts this does not reflect your usage -not a single one of them ever considered using a Chinese set of studs -the vendor they concluded was best came in at $355 per set, which everyone felt was a very reasonable price So my conclusion is that while you're technically correct that some people replace them as wear items, I don't think this applies to your use case. Let's be honest here, if you're buying unknown quality fasteners to save 50 bucks are you ACTUALLY going to be replacing them every year or two? Everyone who replied advised against the ones you bought and you didn't care for their advice... ¯\_(ツ)_/¯ |
IllSic_Design2124.00 |
02-04-2021, 08:35 PM | #15 |
2002
Rep 3,731
Great idea.....buying used wheel studs and nuts. Like you said above...people replace them for a reason. Why would anyone buy a set of used ones?
Congratulations.....you won the internet Last edited by iqraceworks; 02-05-2021 at 06:56 AM.. |
02-04-2021, 11:56 PM | #16 |
89
Rep 1,067
FCP euro also sells wheel studs. They are very similar to the studs that come in the venom kit. I have both. Also the venom spacers aren't the lightest but I used them for a couple years. Only issues were the end of the stud stripping when removing it, but that's probably from the threadlocker and not getting it hot enough or overtigtening the stud when installing. This led me to replacement studs at FCP Euro.
https://www.fcpeuro.com/products/90m...12x15-90mm-brs https://www.fcpeuro.com/products/bmw...12x1590mmbrskt
335xi
02-05-2021, 06:55 AM | #17 | |
2002
Rep 3,731
And yes......if you try to back out the studs with that allen head on the end of them, it's going to strip out. You need to "double nut" them to get them out...it takes about 250ft/lb-ish to break them lose with that red locktite. Thanks again!
02-05-2021, 04:01 PM | #18 | |
89
Rep 1,067
Heating it up with a torch also works and then you can back them out pretty easily.
335xi
