New turbos + new feed and return lines-Leaking...
01-25-2021, 05:06 PM | #1 |
101
Rep 304
hey everyone, i Just finished swapping in new turbos, new water and oil lines, oil pan gasket, and a ton of other maintenance stuff. Since i can never catch a break, I am apparently leaking from what i believe is an oil feed line since it only happens when the car is running.
I don't believe it is the returns as I could get my head up near enough and it didn't seem like it was the returns. Has anyone ever tried removing/tightening the feed lines with the subframe in place? I removed and reinstalled with the subframe out obviously. Is it possible to reach them with the subframe still in place? If i have to drop it again i might just burn the fucking car to the ground...This car has been nothing but problems since i bought it and never having a single fun time with it im about over it. Last edited by haaken675; 01-25-2021 at 05:32 PM.. |
01-25-2021, 06:28 PM | #2 |
147
Rep 517
Man do I feel bad for you. You might be able to reach them from the top if you remove the boost solenoid tray..if you have access to a lift just man up and drop it. Only takes about an hour once you have done it already..best of luck.
01-25-2021, 06:37 PM | #3 |
2124
Rep 2,758
I was just able to replace my turbo coolant feed lines with only removing the down pipes, and the oil feeds are right above the coolant feeds so you should be able to remove them.
01-25-2021, 06:57 PM | #4 |
300
Rep 884
I did just relocated inlets over the weekend and with my down-pipes off I was able to reach around the turbo area so it's possible man you just gotta have some patience.
2013 335is - sold
2011 335d |
01-25-2021, 07:23 PM | #5 |
101
Rep 304
Well, that sucks...
I’m guessing I probably will need new downpipe gaskets now...that will literally be 2 sets in less then 100 miles. Iv had a LOT of performance cars, but this has literally been the most aggravating to work on out of 20+ vehicles. My m52 swapped, turbo e30 that Iv built from the ground up has been less of a hassle to work on... |
1Bad335turbopsi57.50 |
01-25-2021, 08:44 PM | #7 |
101
Rep 304
Taking the downpipes off of the turbos is such a bitch that I don’t think it’s worth risking it...then again, that’s why I bought all new oil and water lines at a high cost and look where I’m at still.
01-25-2021, 09:00 PM | #8 | |
2682
Rep 6,314
Took it off just to check if I had shaft play in my turbskies, I found it oddly easy and I daily mine in the winter here. It was last touched about 2 years ago before that. |
IllSic_Design2124.00 |
01-25-2021, 10:57 PM | #9 |
612
Rep 1,272
I made the same mistake of buying new lines. Turns out they came with crappy O-rings. Less than a year later, they were leaking. When I got them out, they were rock hard.
01-26-2021, 04:13 AM | #10 | |
973
Rep 3,219
Not being funny but this is why I don't DIY when I'm not 100% sure of what I'm doing. Rather pay a garage and get it done properly. |
01-26-2021, 05:03 AM | #11 |
101
Rep 304
01-26-2021, 09:38 AM | #12 |
1907
Rep 6,968
You probably need to drop the subframe, remove the engine mount & water pump etc to get to it.
I'm guessing you pinched the gasket. Did you dip the gasket in fresh engine oil prior to install? Also, torque spec is 8nm to the turbo & 9nm to the block. You should have a 1/4 drive torque wrench to do that. This really sucks; I feel for you. It's ALWAYS a good idea to buy OEM gaskets on the N54. |
01-26-2021, 10:06 AM | #13 | |
101
Rep 304
Pre lubed all o rings on new OEM lines. Was super careful with all of the because I didn't want this exact problem...Used a 1/4 torque wrench that I trust. I'm thinking more and more that its the feed from the block where the two feed lines meet. I wasn't necessarily thrilled with how they went together. I'm going to start there and hoping I can get to it without taking the engine mount off. Not sure if it's possible. Would be nice if there was a way to actually check everything without having to put the whole car back together. I REALLY don't like the idea of starting the motor while hanging from an engine support bar. Who would have thought my motor swapped turbo e30 was easier to work on. |
01-26-2021, 10:31 AM | #14 |
858
Rep 1,364
Drives: 09 E90 335i M-Sport 6MT RWD
Are you rwd or awd?
I've replaced N54 turbos a few times (rwd) and subframe has been left in place each time. Awd I don't think you have that choice |
TheMidnightNarwhal2682.00 |
01-26-2021, 10:44 AM | #15 | |
2682
Rep 6,314
So in your case, was it still fairly doable with subframe in place or if you would do it again, would it be with the subframe removed? |
01-26-2021, 11:06 AM | #16 | |
858
Rep 1,364
Ya I just remove the downpipes, IC, swaybar and waterpump; Put a jackstand under the oil pan(with wood between) and voila. Reach 1 arm around each side of the subframe and there is tons of room. Funny enough I'm doing 2 more this winter (uninstalling my RB stocks to put on my fathers and put some RB ones onto mine). |
01-26-2021, 11:28 AM | #17 |
101
Rep 304
I hadn't though about using the support bar and only removing the engine mount arm..That might be the play. The front turbo you can gain access to the oil line from the wheel well, although its tight seeing what you are doing with the strut in place. The rear, not sure on that one.
01-26-2021, 11:32 AM | #18 | |
2682
Rep 6,314
01-26-2021, 11:47 AM | #19 | |
858
Rep 1,364
X-drive I have no experience but I've heard its more of a hassle |
01-28-2021, 10:57 AM | #20 | ||
1907
Rep 6,968
Just my two cents |
feuer4277.00 |
01-29-2021, 07:11 PM | #21 |
2124
Rep 2,758
I did turbos with subframe in place, only removed motor mount. It was not bad at all, it would definitely be easier with the subframe removed, but it's a LOT more work to remove the subframe than "just 4 more bolts", I know as I just recently had the whole subframe off a few weeks ago. When I do turbos again I'm going to leave the subframe like I did before.
01-30-2021, 09:12 AM | #22 | |
1907
Rep 6,968
All the small bolts had some level of build up on them, so I spent a lot of time with a SS wire wheel on my drill cleaning up all the rust etc., through out the project; that's a lot of bolts & nuts! That's one of the idiosyncrasies you have to do when you live in the "rust belt" of the country. Needless to say, I just love all the videos you see on YouTube where a guy clearly lives in the southern part of the country and everything comes off & goes on so cleanly and effortlessly. |
feuer4277.00 IllSic_Design2124.00 |
