Headlight upgrade from bayoptiks
01-09-2021, 10:04 AM | #1 |
Rep 5
Can anyone help with coding of headlights? I upgrade my stock lights using bayoptiks and now have the Vision Retrofit with sequential led eyebrow. I have a pre lci e92 335i 2009. Below is picture of what they said needed to be coded. I am using protool and trying to avoid going to my local shop. When i go into protool i am having trouble finding what they are saying needs to be turned off? Thanks for the help.
02-01-2021, 07:43 PM | #2 |
50
Rep 59
Drives: '08 E92 335i
Interesting language they decided to use in the instructions.. Cold/Warm?? I would give them a ring and clarify. I am looking at picking a set of these up in the near future, do post some pictures after install!
*Not professional advice
'08 335i M Sport |
02-03-2021, 01:46 AM | #3 |
2852
Rep 4,322
Seems straight forward if you’ve used the protools app
These would be the steps with the app Clock safety from Main menu Select frm Click coding Click edit coding Click “standard” at the top Find the cold and warm checks for corner bulbs Disable both Find angel eye warm and cold check Disable both And click save once done with each step. Steps For the 12.6 voltage From the FRM menu: Click functions Click Adjust voltages Select angel eye voltage and move to 12.6v and save. All this is off the top of my head, it should be exact based on the app layout, if not very similar.
E90 335i-408WHP. Alpine over Terra brown
E70 X5 35i M Sport-Stage1 Tune. Alpine over Black E91 328 M Sport-Alpine over Black-Alpine over Saddle brown. E93 335i-DINAN tuned. Alpine over Saddle brown |
02-06-2021, 02:41 PM | #4 |
357
Rep 1,724
This is how BMW describes their bulb checks. So yeah, this makes perfect sense.
'09 335D
