Wipers will not cancel
01-02-2021, 09:35 AM | #1 |
406
Rep 411
Having problems with E90 2010 320d.
The wipers will not cancel, ive pulled the codes from the car. All I done was add a fused wired to fuse 2 for the radio https://drive.google.com/file/d/180s...ew?usp=sharing
Help yourself Software part II, read post 1 : https://www.e90post.com/forums/showt...7#post27890067
01-02-2021, 12:39 PM | #2 |
406
Rep 411
Car runs, lights work, indicators work, dash works.
I did code my DTC, when my abs sensor was playing up, still havent coded it back on. Now showing low battery and wipers still wont turn off. Charging battery overnight. Down to these codes now: Fault Code: 00a550 Fault Explanation:ID failure 1A0h speed Fault Code: 00a3b9 Fault Explanation:CAN ID 19E error failure message status DSC Fault Code: 00e594 Fault Explanation:Telegram steering angle timeout Fault Code: 0049f3 Fault Explanation:Message (speed WHEEL 0xCE) Fault Code: 004c23+ Fault Explanation:Message (torque anF DSC, 0xB6) Fault Code: 004c28 Fault Explanation:Message (speed, 0x1A0) Fault Code: 004c13 Fault Explanation:Message (STAT DSC, 0x19E) Fault Code: 004458 Fault Explanation:Message (STEERING anGLE, 0xC4) Fault Code: 003f62 Fault Explanation:Road speed signal via CAN Fault Code: 00a0b5 Fault Explanation: :Signal detection speed error / DFAHL cable break A0B5
01-03-2021, 04:29 AM | #3 |
406
Rep 411
Got it fixed this morning : FUSE 26 WAS BLOWN + I replaced the Heater Control Panel ( had a spare one, thats the 3rd one Ive killed. Down to my own fault plugging it in when engine was running ). No error codes showing, wipers have stopped going crazy and the DSC errors have gone.
