12-29-2020, 04:36 AM | #1 |
127
Rep 283
Widest tyres
Guy's, what are the widest tyres you can fit on a 2019 440i with 19 inch rims front and rear, ordering some winter wheels and tyres etc, we do NOT get snow hardly ever so that isn't an issue, any advice is much appreciated.
12-29-2020, 05:49 AM | #2 |
436
Rep 844
Ideally you want a new set of rims because You want your winter wheels to be smaller, with a thicker side wall, and narrower. The thicker side wall allows for more play and forgiveness on harsh winter roads and potholes and you want thinner because that increases the amount of weight on the contact surface. Obviously nothing crazy because you still want traction and breaking abilities in the dry but I would go with a 225 over a 255. My summer tires are a staggered 19" setup and my winter setup is square 18/225. On my old s4 tire rack actually recommended I go with a 17" instead of the stock 19". Car was an absolute monster in the snow with them.
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
bellguy127.00 |
12-29-2020, 06:12 AM | #3 | |
1151
Rep 1,521
bellguy127.00 |
12-29-2020, 08:26 AM | #4 | ||
436
Rep 844
bellguy127.00 |
12-29-2020, 09:00 AM | #5 | |
120
Rep 77
Unless it's a super dry but cold climate? |
bellguy127.00 |
12-29-2020, 09:20 AM | #6 |
127
Rep 283
Guy's, i want these new wheels and tyres so my Polished front M sport alloys don't get blasted and destroyed by salt and grit which can be used often through the winter, don't need winter tyres really.
Come next spring the M wheels will be going back on, i should have explained it better lol |
12-29-2020, 01:55 PM | #7 |
277
Rep 833
Drives: BMW F36, E36, E93
If you are worried about grit, then you rather should go for small.
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
bellguy127.00 |
12-29-2020, 05:58 PM | #8 | |
436
Rep 844
I'd go with a square setup, smaller diameter tire which would give a taller side wall, and a set of powder coated rims as you will get more protection and less chance the salt eats through a clear coat or causes other damage.
bellguy127.00 |
12-29-2020, 06:51 PM | #9 |
484
Rep 1,066
If you want wide for the sake of wide, there is a guy local to me running 19x10, 285 in the back. He's lowered a has a hint of camber. F32 n55.
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
bellguy127.00 |
12-30-2020, 01:19 PM | #11 |
277
Rep 833
It will make the change back in spring so much more exciting
Such Fun
