12-19-2020, 06:11 AM | #1 |
204
Rep 383
Codeing HU AUX - how to?
Hi everyone,
I got my MMI installed yesterday and everything is working perfect so far. The only thing I don’t like is it seems my car does not use the Aux input from the quad lock, and I need to plug in the 3.5mm plug under the arm rest. I saw someone was able to code this to work, disabling the arm rest input, but their steps did not work for me. I have CICHB with COMBOX. Car came enhanced bluetooth, navi, office, phone dock enabled. 2013 335i M Sport. Anybody have any insight in how to solve this with Bimmercode? I don’t like the 3.5mm plug as there isn’t a good way the route the cable (without cutting holes). I don’t mind turning off the aux, as I was thinking of converting that to the MMI usb anyway. |
12-19-2020, 10:29 AM | #2 |
204
Rep 383
Ok, for what it’s worth I tried again and while it didn’t work right away, it seems to be working now.
For the record, here is what I did: Coded: In the Head Unit module: CDMM_AUX_HU to active CDMM_USB_AUDIO_SINGLE to not active CDMM_USB_AUDIO_DOUBLE to not active Thanks to BreeeZe for figuring this out. |
SaNGRia990.00 |
09-02-2021, 06:15 PM | #3 | |
Rep 1
Thanks! |
08-16-2022, 11:29 PM | #4 | |
990
Rep 1,353
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 08-17-2022 at 10:59 AM.. |
SuperLomi204.00 |
08-17-2022, 02:12 PM | #5 |
990
Rep 1,353
I have an even better news. Now u can use your USB Aux with 6NF 6FL plus Carplay thru Aux HU.
Here is what i have done and works without any issue : Aux Rear allows while Iphone also connected thru USB AUX w/ cradle
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
vilord489.50 |
12-03-2022, 07:31 AM | #6 |
Rep 25
Hello guys,
I have a e90 2010 with CIC with Bluetooth music etc I have a mmi box which uses the aux in arm rest, I want to use the aux from headunit but skeptical to code as don’t think it would work due to relocating the most fibre connection to the mmi quad lock, any help would be appreciated! |
01-13-2023, 08:04 PM | #7 | |
30
Rep 106
I have a 2013 335i f30 with the HU_Entry system and this allowed me to unplug the front aux cable i had to run to the connection under my armrest. It could be placebo, but i think my audio quality slightly increased? Thank you everyone |
04-15-2023, 03:14 AM | #8 | |
Rep 12
May I know if you did anything else to make it work pls? Thanks! |
