ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > Z4 DIY (Do It Yourself) Articles
  TireRack
      10-14-2008, 12:54 PM   #1
misterawa
John 14:6
misterawa's Avatar
59
Drives: Z4
HELP with Multi-Function Steering Wheel install
I plan on installing a MFST (no paddles) from a 2005 Z4 that I won from ebay onto my 03 Z4. I've seen a thread here on removing the steering wheel and another thread about retrofitting the MFST w/paddle shifts on Z4-forum. Does anyone have some step by step or DIY instructions to help me with installing the MFST? How about parts and part #s? Is this really a DIY job or should I take my Z to a local BMW shop (not the stealer)?
I would really appreciate any advice
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover...
      10-15-2008, 03:52 PM   #2
misterawa
John 14:6
misterawa's Avatar
59
Drives: Z4
Anyone
      10-15-2008, 11:14 PM   #3
1st_Knight
'Entwicklung 85 - Zukunft4'
1st_Knight's Avatar
26
Drives: 04 Z4 SMG DINAN S1
Originally Posted by misterawa View Post
Anyone
Hey Bro, I see you got yourself an updated steering wheel... ...Anyways, what's your e-mail address I will send you the OEM install instructions...
      10-17-2008, 05:28 PM   #4
misterawa
John 14:6
misterawa's Avatar
59
Drives: Z4
Thanks David for the instructions. I was able to locate the parts and I'm gonna attempt to do the install.
      01-08-2009, 05:08 AM   #5
pechs2k
Drives:
hi, does this mean you can control ur stereo via the 05 wheel to the 03 z4?
what if u were to purchase an Z4M steering wheel, would this fit and work?
      01-08-2009, 10:09 AM   #6
misterawa
John 14:6
misterawa's Avatar
59
Drives: Z4
Yes, you can control the stereo with the 05 multifunction steering wheel on a 03 Z4. Install was very easy. I'm not too sure about the Z4M wheel, but I believe it should work as well. Good luck and let us know.
      08-29-2009, 08:20 AM   #7
simonplummer
Drives: 2004 Z4 3.0 SE
Instructions...
Hi there, Is there any chance you could forward on the instructions to me or post them in the forum - I fancy having a go at this retrofit too.
Thanks in advance.
Si
      08-30-2009, 05:57 PM   #8
EMP07
EMP07's Avatar
37
Drives: Z4M
same here, can it be posted on the forum somewhere?
      09-10-2009, 04:28 PM   #9
misterawa
John 14:6
misterawa's Avatar
59
Drives: Z4
Thanks in advance.
Si
Attached are the instructions for the retrofit kit, which should be quite helpful for the install. Here's some helpful info from a thread on Z4-forum. http://www.z4-forum.com/forum/viewto...899&hilit=mfsw You will need to buy p/n 61-13-0-005-197 at around $1.50 from your local dealer for item H (retrofit cable) which is not easily available in the US.
File Type: pdf Z4_Multi-Function_Button_Retrofit_Kit.pdf (612.3 KB, 2028 views)
zpost
