12-06-2020, 12:45 PM | #1 |
6638
Rep 4,145
Drives: '18 M2 6MT
6MT Transmission noise in neutral?
I've been meaning to make a post about this forever, and always forget.
I bought my car used (9400 miles), and since day 1 it has made a light sound when in neutral. The sound is very light, and is sort of a rattle. The moment I depress the clutch it goes away, and the car is super quiet. The car drives perfectly fine, no grinding, no chirping, nothing bad at all, it's just that noise in neutral. Current mileage is 16,000. Does yours do this? |
12-06-2020, 01:04 PM | #2 | |
@lbb_kev
494
Rep 515
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage |
12-06-2020, 01:05 PM | #3 |
846
Rep 1,962
Clutch Release Bearing at a guess. That it disappears when you depress the clutch says yes. Nothing to worry about.
VisualEcho6638.00 |
12-06-2020, 03:06 PM | #4 | |
54
Rep 70
Keep an ear on it to see if it gets louder but if it's just a faint mechanical noise I wouldn't worry about it (or at least I haven't). |
VisualEcho6638.00 |
12-06-2020, 03:28 PM | #5 | |
6638
Rep 4,145
Drives: '18 M2 6MT
Thanks for the info! |
12-07-2020, 08:42 AM | #6 |
134
Rep 177
My M2 chatters a bit in neutral with foot off clutch.
My e82 and e90 did this as well. Never had issues with drivability. |
VisualEcho6638.00 |
12-07-2020, 10:17 AM | #7 |
1717
Rep 1,899
are you sure it's the transmission rattling? On my car it's a slight heatshield rattle. Very slight. Almost Barely noticeable unless you're listening for it.
I found that a bolt had somehow got lost but I've just been lazy to put in the replacement. |
12-07-2020, 11:12 AM | #8 |
2302
Rep 4,162
Mine chatters - but I figured it was the flywheel.
Mods: Yes.
VisualEcho6638.00 Robimplicit16.00 |
12-07-2020, 11:24 AM | #9 |
6638
Rep 4,145
Drives: '18 M2 6MT
Not sure at all, just sounds like mechanical chatter, like it's perfect, almost in time I guess. But I'll listen much closer at the next drive. Thanks for the input.
12-07-2020, 12:47 PM | #10 |
2302
Rep 4,162
Nope -I hear it too, and it's pretty noticeable in 1st/2nd gear up to about 3000RPM.
Mods: Yes.
VisualEcho6638.00 |
12-07-2020, 10:04 PM | #12 |
2302
Rep 4,162
12-08-2020, 10:58 AM | #13 |
6638
Rep 4,145
Drives: '18 M2 6MT
Got an email from my SA this morning, he's been out because of COVID.
This is what he wrote. "I happened to have another 6 speed M2 in the shop this morning. Listening to it at idle in neutral with the clutch pedal released you can hear some light clatter. Press on the clutch pedal and the noise goes away. Sounds like you might be hearing a little inherent throw out bearing noise." |
m3username54.00 |
01-22-2021, 11:20 AM | #14 | |
2302
Rep 4,162
Mods: Yes.
01-22-2021, 11:26 AM | #15 |
6638
Rep 4,145
Drives: '18 M2 6MT
03-27-2021, 06:50 PM | #16 |
45
Rep 51
I have this same problem. I actually just bought 2017 m2 with 70k on it. Hear some very light clatter in neutral. When I push the clutch pedal the noise goes away. I bought the car keeping in mind that I will have to do a clutch job sooner or later. Drives like a dream otherwise.
03-28-2021, 02:53 AM | #17 | |
439
Rep 554
Certainly wouldn't recommend keeping the clutch depressed un-necessarily (eg stopped at lights or in heavy traffic etc) just to stop any noise like someone mentioned earlier, last thing anyone would want is having to pull the transmission to replace a worn thrust bearing. Ideally you replace that bearing when you replace a worn clutch |
03-30-2021, 06:12 PM | #18 |
560
Rep 570
I'd chalk it up as a normal operating condition unless you have had previous clutch work that wasn't performed properly or a premature throw-out bearing issue.
All 3 of my Mcars (E90, F82, F87) have all had 6MT and all of them talk a little at idle w/the car in neutral. The E90 used to rattle a bit on clutch engagement, too. All normal. If it's a problem - it will get worse and figure itself out. My $.02 |
