12-02-2020, 02:09 PM | #1 |
2095
Rep 1,862
Instrument Panel Display
When you change driving modes isn't the instrument cluster supposed to change colors? The top picture is when I am in comfort mode. When I change to sport or Eco there is no color change as depicted in the second photo. Is there some setting I am missing? Thanks.
12-02-2020, 04:44 PM | #2 |
12
Rep 10
Yes, Unfortunately with the M display rather than the standard one (assuming you coded that in) with colour change with different modes doesn't apply. I have currently not found a way to fix it. (if there even is a way to do so)
which is why after I realised I coded back to the standard display which changed. its the same reason you can't the tacho on the HUD, but you can with the normal display setup. |
12-02-2020, 08:54 PM | #3 | |
2095
Rep 1,862
12-03-2020, 11:18 AM | #4 |
2095
Rep 1,862
So I recoded and got back the instrument panel changes with each driving mode. I believe I used to have an M235 logo where the M logo was in the first picture but now nothing is there. Did you have a similar issue? I was thinking whether or not the recent software update caused the issue. I am on update 7/2020.54. The logo I was referring to is pictured below on another car.
12-04-2020, 09:32 PM | #5 |
12
Rep 10
It is to do with the new update. just recode that bit and it will be fine. I had just the M previously then with the recent OTA it reverted back to M235i and I think I prefer it.
