N52B30 does not start
11-26-2020, 05:47 AM | #1 |
Rep 21
After the broken DISA and and a new valve i put everything togheter again. i had some problems with the KGE, the hoses wont snap in, after hours i made it but i think when i installed the intake manifold it could have come off again.
After assembly i delete all errors and start my car, it started, but went out as the petrol line slipped off from the ijection rail. i hadn't closed the clutch lock from it. after i reconnected and vented the line i wanted to start the car again, but it wont to start. starter is working, several tries later i read out the error log. 2A9A Nockenwellensensor Einlass, Signal i changed magnetic valves, camshaft sensors, but the error comes back and the car wont start. every 4-5 start tries, the car almost starts... i have no more idea, maybe crankshaft sensor? skipped chain? |
11-26-2020, 12:10 PM | #2 |
1998
Rep 2,026
Drives: 2008 E92 328xi
Did you end up doing any work to the head? I'd wonder if the engine was timed correctly if you indeed did remove the head and such. Have you checked it there are any fuses related to the camshaft position sensor wiring? I think it's fuse F02
11-26-2020, 01:04 PM | #3 | |
Rep 21
i have not checked any fuses, i'll do that first thing tomorrow. Could A0B4 indicate the starter? no problems previously. |
11-26-2020, 01:26 PM | #4 |
1998
Rep 2,026
I'm not sure what that code means but I have gotten it before when I get a crank but no start situation. Last time that happened I had blown fuse F11 which runs the crankshaft position sensor and will throw codes for disa valves and the evap vent valve aswell as oil level sensor
11-27-2020, 09:45 AM | #5 |
Rep 21
11-27-2020, 03:55 PM | #7 |
217
Rep 642
Why don't you take off the intake manifold and recheck everything again. You crankshaft position sensor wire could have possibly come off or broke as if the wiring is not routed right, it can cause too much tension and come off. I've actually had that happen to me. And it's not just that wire, the wire to the power distribution box to the connector mounted on the manifold and come off too. I think those two problems might be it especially if you're saying some hoses could have come loose when reinstalling the manifold. Also remember there is a sensor plug that often gets overlooked to reconnect down there as well next to another hose by the distribution box area.
11-27-2020, 04:55 PM | #8 | |
Rep 21
On intake manifold system i checked the wirings: adjuster 1&2, angle connector, pressure sensor and throttle. |
11-27-2020, 05:11 PM | #10 |
Rep 21
can you find it over bmw etk?
http://www.bmw-etk.info/parts-catalo.../2004/02/48483 |
11-27-2020, 06:05 PM | #11 | |
217
Rep 642
It's on the bottom of the bracket on the opposite side of that bottom hose connector. Most people tend to forget to reconnect that one. My best guess is either that is not connected, or the crankshaft position sensor wiring being pulled out or broken/ripped. Possibly a combination of both. |
11-28-2020, 04:24 AM | #12 | |
Rep 21
it also doesn't solve the problem with poor compression. ~70psi (5bar) |
11-28-2020, 12:11 PM | #13 |
Rep 21
11-29-2020, 01:39 PM | #14 |
Rep 21
Update:
A new camshaft adjuster brought the solution. everything rebuilt and adjusted again and the engine started |
E92William1998.00 |
