Opinion on engine flushes?
11-18-2020, 12:24 PM | #1 |
3942
Rep 2,644
Drives: 2019 BMW 540
First off I want to say, No I am not going to use any sort of engine flush. I was just curious, so I looked up "best engine flushes" on google and what not and got mixed reviews. Some people were saying engine flush is like magic and does no harm to your engine. Some folks were saying it can harm your engine seals which will cause your engine to leak. So, I went ahead and emailed LM (liqui-molly came up has one of the highest-rated engine flushes) application engineer about their pro-line series engine flush and asked him where the deposit from the flush goes? Does it all drain out of the engine or does some stay in the engine? He emailed back and said with LM engine flush the deposit drain out from the old motor oil. But in theory, motor oil doesn't drain out of an engine 100%. There's still about 1% of oil left in the engine. I personally wouldn't use any sort of engine flush in my car. Oil changes have been done every 5-7k miles or 6-8 months (whichever came first) by me and the previous owner using either BMW OEM oil. So, internally my engine should be clean. Let me know what you guys think.
11-18-2020, 12:26 PM | #2 |
626
Rep 2,099
I'm torn on this one as the "BMW Doctor" said not to use any...so with that, I'm inclined to think that we should. :P
Mosaud19983941.50 franksinatra9.50 |
11-18-2020, 12:29 PM | #3 |
3942
Rep 2,644
Why though I'm afraid to use it. I don't really want to harm a $5k-$6k engine using an $8 product. Plus, if you change your oil every 5-7k mile, I don't think you should have any "deposits".
11-18-2020, 12:57 PM | #4 | |
626
Rep 2,099
In moderation, say every 3 years or so, I think its fine as a maintenance item and can only do good. You're supposed to flush them all anyway immediately after use (which includes idling the engine). So most of it is detergent or alcohol (burn your problems) anyway, so the effect is somewhat minimal. If your car is used or giving you some odd idling, its not a bad idea if you haven't done it before. But as you say, an engine that has mostly highway miles and regular oil changes twice a year or whatever your oil analysis says, is probably fine without it. As an N52, you probably have less issues and a good fuel system cleaner is about all you really need. A few people have stuck boroscopes down there and these engine cleaners do take away some of the carbon deposits. So it's up to you. If it ain't broken or bogging, don't fix it. |
Mosaud19983941.50 |
11-18-2020, 01:07 PM | #5 | |
3942
Rep 2,644
11-18-2020, 03:49 PM | #6 |
Hoonigan
6849
Rep 3,000
Drives: '09 328i, '98 Wrangler
1. BMW Doctor is a quack. A lot of his "advice" goes against factory service info, and some of it doesn't even make any sense.
2. A flush wouldn't harm a clean engine, but then again if it's clean you don't need it. In a severely sludged engine, a flush is harmful because it can loosen too much sludge at once and clog oil passages, the oil pump pickup, etc. For a dirty engine the best thing you can do is just use good synthetic oil and a good filter and change it regularly. This will clean the engine gradually as you drive. |
Phil325i615.50 Mosaud19983941.50 |
11-18-2020, 06:36 PM | #7 |
996
Rep 2,287
I don't plan to introduce anything to my lubrication system that might have a negative affect on the various seals, gaskets or bearings found in these motors. Don't care what the label says.
Good oil change intervals with the correct oil is the best recommendation anyone can give. Follow the guidelines and you won't need to flush the motor. |
Mosaud19983941.50 houbmw65.50 |
11-19-2020, 12:27 AM | #8 | |
3973
Rep 7,215
But personally, I've done the seafoam thing, and various other engine snake oils in the past. Save the $10 and buy yourself a take-out lunch instead. |
bluewater328625.50 |
11-19-2020, 07:49 AM | #9 |
135
Rep 173
While I haven't used anything I classified as a "flush", I have used the LiquiMoly Ceratec before. Maybe snake oil, but I figure at 200k+ it can't hurt to have some extra wear protection.
Regarding flushes though, if you're performing your maintenances consistently then there shouldn't be a need for flushes, right? Just ask EfThreeOh... Last edited by CDirks; 11-20-2020 at 06:55 AM.. |
Mosaud19983941.50 |
11-19-2020, 08:08 AM | #10 |
31
Rep 131
I have used liquimoly's engine flush treatment at 100k miles, mostly because it came free with my oil. Hard to say if it cleaned up much since there wasn't much visible gunk in the first place. When I took my valve cover off it was very clean in there so maybe that helped.
But like everyone else has said, fresh engine oil is one hell of cleaner. In fact I occasionally use leftover oil to clean all sorts of metal things - it works wonders on rust! |
Mosaud19983941.50 |
11-19-2020, 10:35 AM | #11 | |
3942
Rep 2,644
11-19-2020, 10:58 AM | #12 | |
135
Rep 173
If you plan on keeping your car for the foreseeable future, I don't believe it to be a waste of money at all |
Mosaud19983941.50 |
11-19-2020, 12:00 PM | #13 |
1998
Rep 2,026
Drives: 2008 E92 328xi
11-19-2020, 12:43 PM | #14 | |
3942
Rep 2,644
11-19-2020, 12:52 PM | #15 |
1998
Rep 2,026
Engine flushes are the same imo when it comes to arguments as transmission fluid changes on high mileage cars. I've never had them do anything bad but there's always that one guy who knew some guy who knew his cousins friend who had an issue supposedly because if it...
Chances are nothing is gonna go wrong with it, it's meant to be run on the engine at idle for barely 5 minutes and it's a high detergent additive that dissolves carbon and sludge build up into a liquid so it can be drained out on the oil change after you're done running it. If an engine flush supposedly ruins one of your seals it's because that seal was barely sealing with a piece of sludge. Engines aren't meant to have carbon and sludge inside, unless your engine is holding on by a thread it can't do any harm |
wakrus660.00 |
11-19-2020, 02:21 PM | #16 |
17317
Rep 18,738
Snake oil.
400,000 miles. OCI still above 14,000 miles. BMW oil and MANN filter. Been in the top and bottom of my engine over the years. Posted pictures. Never a spec of sludge. |
11-19-2020, 02:33 PM | #17 |
3942
Rep 2,644
11-19-2020, 03:00 PM | #18 |
1998
Rep 2,026
I guess it's good if you buy an engine that already has sludge in it contrary to doing it for no reason on a clean engine
Mosaud19983941.50 Efthreeoh17316.50 |
11-20-2020, 05:42 AM | #19 |
17317
Rep 18,738
And I'd add, if you buy a car that has engine sludge, then the car has not been properly maintained and cared for. Sludge forms from not properly heating the engine (very short trips) or very long oil change intervals where the oil looses its additive package, and way beyond any manufacturer's OCI recommendations.
11-20-2020, 08:26 PM | #20 |
17317
Rep 18,738
That's how it is usually sold... by the bottle.
11-21-2020, 06:49 PM | #21 |
672
Rep 733
I've always been very wary of engine flushes, especially those which state they should only be used for 10 minutes maximum with an idling engine. (Like Motor Medic).
That seems to indicate that the product reduces the film strength of the oil so significantly that loading the engine at all could cause significant bearing damage (it doesn't take much). Personally, the risk there is too great for whatever gain. Even if you follow the instructions, you're operating the engine at a much greater risk of significant damage you may not notice until many, many miles down the road. Over time, and with correct operating temperatures always reached, a good oil will be able to reduce the amount of sludge on it's own, though you may want to change it more often since additive/detergent packages deplete. Back in high school, I used Motor Medic Motor Flush on my Abarth to try to see if it'd have any effect on an issue I thought was with multiair, and when I drained the oil it was alarmingly thin- not surprising considering the viscosity of the flush which makes up 1/4 of the engines oil capacity itself (though I kept it at 1/8). Go shake a bottle of motor flush and I think your decision about using it will be made. Last edited by JonOhh; 11-21-2020 at 06:58 PM.. |
Mosaud19983941.50 |
11-22-2020, 01:57 AM | #22 |
1998
Rep 2,026
I remember when I worked at Autozone in highschool we had a guy come in complaining that his engine was making noise after someone sold him an oil "additive" in our store and well they had sold him engine flush and he had been driving the car around with it. No idea what was done about that lol but it sounded like it was ticking like mad. I don't think it's as big of a deal if you don't load the engine though. It was also a fiat a 500L
JonOhh672.00 |
