11-17-2020, 10:36 AM | #1 |
Rep 9
Empty ConnectedDrive menu
Hello, guys.
So I have recently bought an 2016 320d and I'm really happy with it. The previous owner was a skilled code and retrofitter and has upgraded the cluster to 6WB, changed the head unit to the one with 4GB RAM and flashed ID6 and coded some other stuff in the car. The only issue that has been bugging me for some time is that my ConnectedDrive menu is empty. The car has Connected Drive options on its VIN. 6AM Real Time Traffic Information 6AC Intelligent Emergency Call 609 Navigation System Professional 7XP Navigation Package Connecteddrive 6AK Connecteddrive Services 6AE Teleservices 6NS Enhanced Telephony With Extended Sm 6AP Remote Services However, the only entry in my ConnectedDrive menu is BMW Assistance. Also, if i hit option, the Update BMW Services is greyed out and Login also will be stuck at Checking user data. From factory the car had NBT Evo ID4 so there was no change involving the ATM. In fact, the previous owner has the car added on his account in the BMW Connected app and we tested it today. The car operated a remote command sent by him, so I'm sure the mobile connection works. I plugged my laptop with ESYS today and read the VO and searched through FDL. I couldn't find anything suspicious. All options related to ConnectedDrive or so were enabled. Do you have any suggestions? I have read a lot of threads but nothing seemed to help. |
11-17-2020, 10:43 AM | #2 |
472
Rep 1,659
Drives: 2022 WRX World Rally Blue
Your subscription has probably run out.
Look on the BMW Connected Drive website. It should tell you which services you have active. It probably doesn't help that the other owner has the car on his subscription. Have him remove it and then look on the website
Rick
11-17-2020, 10:46 AM | #3 |
588
Rep 2,302
No solution, but an idea.
Do you have ISTA? So first you can read out the error memory. And then somewhere in ISTA you can do something like reactivate the connection or the repair the connecteddrive services. Maybe you can try it. |
11-17-2020, 10:49 AM | #4 |
Rep 9
The car isn't linked in any way with my account. I can't login and I have no "Messages" find the code and register it on my account.
This is how my menu looks like. @atzebmw thanks for the suggestion with ISTA. I don't have it yet, but I can install it and check what you described. |
11-20-2020, 03:13 PM | #5 | |
Rep 9
This is what i found relevant to communication module. I couldn't find any relevant information on repairing connecteddrive services in ISTA or on other forums. I thought about buying an WIFI Antena and plugging it in. I don't really understand the Bluetooth error since my bluetooth is working just fine. Do you think you can point me to a source for the repair in ISTA you mentioned? I don't have much experience with ISTA so maybe I don't know where to look for it. Thanks. |
11-20-2020, 04:01 PM | #6 | |
588
Rep 2,302
11-25-2020, 02:57 AM | #7 |
Rep 9
I've run the selected procedure. It can't update my ConnectedDrive services for some unknown reason and it also mentions there are memory faults in the communications module.
I coded WLAN_DIAGNOSE to false so that I could remove the Wi-fi antenna error. However, I had no luck in updating my services. I asked my local BMW ConnectedDrive support to register the car to my account. I can make remote commands and track GPS, which is enough for me. There might be a problem with my iDrive software or unit. I'll try to find a way to update it. Thanks for the help. |
12-03-2020, 02:06 AM | #8 |
472
Rep 1,659
Did you ever get it fixed??
Rick
12-03-2020, 03:48 AM | #9 |
Rep 9
Hey. Unfortunately, not.
I didn't manage to update my BMW Services by any means. It didn't work even through ISTA. There must be something wrong with my iDrive i guess. I am fine with having remote control on my phone. I guess I'll have connected services on my next car . |
12-03-2020, 08:01 AM | #10 | |
588
Rep 2,302
Your car has similar features to mine. My car has 6WB retrofitted, ID6 retrofitted from ID4 and i have the working connecteddrive menu. And i also read that you have E-Sys. So we can compare the codings from my headunit with yours. If you want you can send me the CAFD from your headunit and i can compare it with mine? Or i send you my CAFD and you can compare it yourself? |
12-03-2020, 02:52 PM | #11 | |
Rep 9
I really believe that it isn't a coding problem, but something wrong which blocks me from hitting the "Update BMW Services" which is supposed to bring up the entries in the menu. I'd try updating iDrive but i wouldn't know what to install and i'm afraid of losing all my extra coding. Thanks for help. |
12-03-2020, 03:34 PM | #12 |
1312
Rep 885
FWIW - this might not be your issue - but I'm pretty sure that if a VIN is already registered to a user, ConnectedDrive won't let you register it... Your seller needs to drop the car completely from his account, and phone app - it sounds like it's still tied to him (and their ConnectDrive subscription is expired).
12-03-2020, 05:43 PM | #13 | |
12
Rep 48
when did the items in the CD menu dissapear? (Did you code something/ did you press "update services"/ just suddenly without doing anything) Do you know if the preowner swapped the ATM with another one or did he just change the HU and the current ATM ist still the stock one? If you have ESYS, connect to car and click "read coding" on HU and ATM. it should show short VIN on ECU list. if it shows you car VINon HU and ATM itīs an coding issue. If it shows another VIN on one of the two ECUs, a CAN-Filter was used and updating services will remove services after pressing "updated service" once and will stay greyed out after. if "update services" is greyed out, that means that either there is an communication issue between HU <-> ATM (VIN mismatch) or ATM <-> BMW servers. With ista you should be able to check if ATM is connected (showing LTE). if you haven done anything and the services suddenly stopped showing, you can try to unplug the ATM power plug and wait for 1h-2h. If ATM isnīt blocked by BMW, it should reconnect. |
visionaut1311.50 |
12-08-2020, 12:32 PM | #14 |
25
Rep 31
Your problem happens with ID4 to ID6 retrofits when using original ATM in car if for some reason "Service Update" is initiated by BMW backend.
Let me explain: When you do "Update services" in car, headunit sends to BMW servers request for provisioning data for actual hardware in car HU_NBT2 and ATM1, so BMW server will send SIGNED provisioning file to EVO and ATM. When this update is initiated by BMW, server is looking at car's factory ilevel to determine the car configuration so will send to EVO and ATM ID4 type of provisioning which is UNSIGNED. Unsigned provisioning data is rejected by both EVO and ATM so headunit remains with no provisioning so does not know even the ip address of the server to request them again, hence the greyed out menu. Solution: Manual upload of provisioning data files with Tool32 or Online Services Update job in ISTA but ISTA must have online connection to BMW backend, so a cracked ISTA will never work, only online ISTA connected to dealer ISPI Next server.
Current cars: 2016 F13 640XD ; 2017 F36 420XD
Past cars: 2010 E93 320i ; 2008 E60 530XD ; 2006 E90 320D |
09-13-2022, 08:51 AM | #15 |
Rep 18
I have a similarity problem too.
I had 6WA, with NBT (ID4) and TCB 3G. I retrofitted the 6WB, with NBTevo (ID5 with ID6 graphics) and 4G ATM. Everything works, the Connected menu is populated with Weather, News, Flickr, etc etc. I can - from app - start remote commands (open, close and beep). But most importantly (for me) it doesn't work. It does not come out 'ALL OK' and it does not show me the details of windows and doors (if closed or open). From the Connected Drive site I can buy the usual packages I bought with the TCB 3G, and not new with 4G .. By making a CarData, I am returned 'SIM status': ACTIVE. I called Connected drive and I let myself dare the IMEI of the sim that sees a screen: it coincides with the label of my new ATM. Can you help me to enable the status of the doors and windows from the app? edit: the VIN is original MINE. In ATM and in HeadUnit.. All original |
12-25-2022, 05:07 PM | #16 | |
36
Rep 398
Have you solve this? |
12-26-2022, 04:46 PM | #17 |
153
Rep 425
This is happening to me too and a few other users. We have the remote commands. Just no weather etc load in car.
Id6 i have fitted, not retrofitted Something on bmw side i think |
01-04-2023, 04:25 PM | #19 |
36
Rep 398
01-05-2023, 11:13 AM | #20 | |
Rep 18
I've made 10 calls and reports to Connected Drive in the last year. They don't want to help me here. But I'm also hiding the retrofitt (iDrive 4 + TCB 3G --> iDrive 6 + ATM 4G) for fear of being permanently banned |
