11-12-2020, 10:28 AM | #1 |
16
Rep 23
Repair Pricing- This seems outrageous
A friend of mine has a 2013 328i with approximately 146,000 miles on it. He has been getting an intermittent error message on the dash saying “drivetrain malfunction” but no other warning lights, until the other day when the check engine light came on along with the error message. Cycling the ignition was clearing the error and it would stay gone for several starts before returning. The car felt sluggish and underpowered when the error was present and had a slight rough idle, but felt fine when the error was gone. He has now taken the car in for diagnostics. The quote that the dealer provided says “Turbocharger - exhaust elbow: turbocharger replacement $5488.36” and “Clutch assembly: faults present for clutch slip $2016.95”. These prices seem absolutely outrageous to me, although I do most of my own work and I’m not familiar with this car or engine; most of my knowledge is centered around VW’s and my N52 powered Z4. What are your thoughts? I’d really appreciate any input. I’ve already advised him to get a second opinion from an independent shop, but we have very limited choices in our area.
2006 E85 Z4 3.0i: manual, sport package, premium package, sport seats, xenon headlights, premium audio, navigation, no mods yet.
11-12-2020, 10:38 AM | #2 | |
516
Rep 1,452
11-12-2020, 10:46 AM | #3 | |
1734
Rep 537
11-12-2020, 10:49 AM | #4 |
417
Rep 919
For $20 he should get a code reader.
Very doubtful he needs all of what the dealer suggested...possible he needs something else entirely...and there's lots he can do easily to save himself thousands. 'That' dealer just wants him to buy a new car.
11-12-2020, 11:58 AM | #7 |
313
Rep 272
turbo parts cost is just over 1k, that can be DIY'd (might as well upgrade). I'm guessing the car is an MT, and the dealer wants to replace the clutch? typically from what I read with the autos they blanket quote a new/used transmission for any error and it is much more than 2k. I'd probably just buy a clutch and have it swapped out if I didn't have a lift.
dealer charges ~800 for plug and coil service and ~200 for a cabin filter change... that should tell you what you need to know about dealer service costs. |
11-12-2020, 07:32 PM | #8 | ||
245
Rep 500
11-12-2020, 07:50 PM | #9 |
1599
Rep 3,748
At 146k miles time to trade sell just my opinion.
With my current car... Once it past the 100k miles mark. I will be weighing an option to sell when more expensive repair will start to creep up. Just my 2 cent. |
11-13-2020, 12:43 AM | #10 |
483
Rep 1,066
A brand new oem turbo which comes with manifold is around 1400 shipped online. Install is around 10 hours so at 150 an hour a new turbo is around 3k. Mhi turbo upgrade is 1300, oem replacement is actually more expensive. Mhi gives you a power boost of around 30%, but on the stock tune will give some grunt but nothing crazy. You don't need a tune with it.
Transmission slipping for a new clutch is around 2k with labor included. However you can get a dual mass flywheel and clutch kit for around 900 shipped. The labor is what gets you. The f30 has a dual mass flywheel and can't be resurfaced, thus you replace it when you change the clutch. Clutch kit LuK DMF154 Dual Mass Flywheel https://www.amazon.com/dp/B01N4GF6RG..._k0IRFb7CDQ98D Flywheel LuK DMF154 Dual Mass Flywheel https://www.amazon.com/dp/B01N4GF6RG..._k0IRFb7CDQ98D Stage 1 turbo https://www.turnermotorsport.com/p-6...turbo-upgrade/ Of course it can be cheaper if you utilize the forum sponsors too ! Take it to an Indy bmw shop, have them diagnose it and tell you what you really need.
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
BimR245.00 |
11-14-2020, 01:22 PM | #11 |
16
Rep 23
Update
Thank you all for the feedback so far. Trading the car is less than ideal for a variety of reasons.
My friend took the car over to Autozone and had the codes scanned. The only code that came up was P1290. A quick google search seems to indicate that it may be the head temperature sensor or possibly an issue with the wastegate actuator. He's taking the car to an indy shop to get properly diagnosed. I'll update again when I hear more. Does anyone have any other thoughts about what P1290 could be?
11-14-2020, 02:13 PM | #12 |
8264
Rep 16,111
Look it up here:
http://bmwfault.codes/ |
Pauloxxi339.00 |
11-14-2020, 09:12 PM | #13 |
127
Rep 339
Price for turbo, is real...including install...Just saying...Turbo and exhaust manifold are one unit...can't say for sure that's the problem but price, if it includes install, it is correct, and in case you were wondering it doesn't seem to be a dyi, unless you have access to a lift and have special tools, and small hands...it takes a trained mechanic about 8 to 10 hrs...and that's just the turbo, google it if you don't believe me. The transmission issue, not a clue on that one. BMW doesn't like selling pieces of that particular turbo (N20;N26) usually they want to replace the entire unit, something about about oil blow by and carbon build up on the exhaust manifold, byproduct of direct injection, I suppose.
11-14-2020, 10:17 PM | #14 | |
1321
Rep 1,640
2020 M550i (G30) | Carbon Black/Black Nappa | DHP | DAP | Executive | Luxury Seating | Park Asst | Ceramic Controls | Front/Rear Heated Seats | 20" 668M wheels
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) |
11-14-2020, 11:22 PM | #15 | ||
439
Rep 1,120
Drives: 2015 BMW 435i Xdrive MSport
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
11-15-2020, 08:05 AM | #16 | |
1321
Rep 1,640
If someone is able do it, it probably takes some tinkering. The indy I go to isn't the tinkering type. They do a proper job and warranty their work. I, too, prefer it that way.
11-15-2020, 09:54 AM | #17 | |
439
Rep 1,120
11-15-2020, 10:14 AM | #18 | |
2419
Rep 4,462
Drives: '23 X1 28i xDrive
11-15-2020, 10:39 AM | #19 | |
5897
Rep 10,265
11-15-2020, 11:50 AM | #20 | |
516
Rep 1,452
11-15-2020, 12:25 PM | #21 |
8264
Rep 16,111
I doubt that they painted it. They probably used undercoating, which does help prevent rust from spreading by depriving it of oxygen. They might have used a rust stabilizer first, like this: https://shop.advanceautoparts.com/p/...B&gclsrc=aw.ds
tex26702418.50 |
11-15-2020, 03:26 PM | #22 | |
516
Rep 1,452
