Need some help fitment !
11-08-2020, 01:36 PM | #1 |
Rep 30
Hi Bimmers
I want to ask you guys about the wheel fitment and tires as well ! I have 2009 335i xdrive sedan with KW suspension. I am looking for new 18" wheels. 1. If i buy the front 18x9.5 +35 offset Rear 18x10.5 +22 offset Will be fitting directly or should i have to do fender rolls and other thing for fitting that size of the wheels? (I do not want to fender rolls, rubbing and others) 2. If those wheels fit directly to my car, what size of the tires should put on them front and rear? Thank you ! Hope you guys safe all the time |
11-09-2020, 03:00 PM | #2 | |
BimmerPost Supporting Vendor
3551
Rep 6,798
Those wheel sizes are quite aggressive for the non-M E9X chassis and will be far from a direct fit on a car equipped with KW coilovers. The front 18x9.5" ET35 typically needs a 5mm front spacer to clear the stock inner suspension components. However, with KW coilovers, your inner suspension clearance is reduced, which will require an even larger spacer (12mm) to clear. With a 12mm spacer, the 18x9.5" ET35 will poke well past the front fenders and will require significant front negative camber (camber plates) to fit without rubbing. The rear 18x10.5" ET22 will need a rear fender roll/pull and potentially some rear negative camber to fit without rubbing, depending on your ride height and specific tire selection. If you are looking for an easier-fitting staggered setup, I would recommend running something a bit less aggressive: Front: 18x9" ET30 or ET31 with 245/40-18 tires Rear: 18x10" ET33 with 275/35-18 tires -5mm front spacers required with KW coilovers -Rolled rear fenders may be required to prevent rubbing depending on ride height. If you have any questions, please do not hesitate to reach out! -Geirsen
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
Julian Ahn1.00 |
11-09-2020, 03:27 PM | #3 | ||
Rep 30
11-10-2020, 02:08 PM | #4 | |
3551
Rep 6,798
I highly suggest checking out our non-M E9X fitment guide if you want to brush up on some of the different wheel fitments known to work for that chassis: https://support.apexraceparts.com/hc...-Fitment-Guide Cheers! -Geirsen
