11-03-2020, 12:32 PM | #1 |
1763
Rep 2,273
Rebeading a tyre - what does it mean?
OH's car has been into the dealer today, one of the issues being a slow puncture. Someone from service just phoned and said the tyre needs stripping and rebeading. As usual, OH had already hung up before coming and asking my opinion, so I wasn't able to speak to service myself.
Could anyone please explain (a) what this means and (b) what might have caused it? Two questions in my mind: 1 - is the tyre faulty? It's fairly new so I'll be kicking off with the place it came from if it is. 2 - is this a result of wheel damage? No mention of it apparently but there doesn't seem much point doing anything with the tyre if the underlying problem isn't sorted. Thx for any help. |
11-03-2020, 12:49 PM | #2 | |
336
Rep 577
As a guess they've found the leake around the edge of the rim where it meets the tyre. I think it just means they'll remove the tyre clean up the alloy and the tyre and reassemmble. |
ZedsRedBaby1762.50 |
11-03-2020, 01:02 PM | #3 |
1763
Rep 2,273
Thanks, that seems plausible and hopefully not too expensive. Not something I've come across before though.
11-03-2020, 01:19 PM | #4 |
301
Rep 821
It’s re bedding the tyre on the rim?
11-03-2020, 01:21 PM | #5 |
660
Rep 1,239
Yup rebeading is just re sitting the bead on the tyre to the alloy, nothing fancy, maybe a bit of bead sealer to help if the alloy is curroded on the sealing face
11-03-2020, 01:44 PM | #7 |
516
Rep 749
Drives: F31 320d xDrive M Sport
Had it a few times on older wheels.
Most likely remove the tyre, get the wire-wheel on the inside of the alloy to scrub away any corrosion or old stuck on stuff, then refit the tyre with a load of tyre bead paste, which stops tiny leaks. If you have a slow puncture and there's no obvious holes, it's not the valve core, then it's often around the bead. If you submerge the wheel underwater you can see little bubbles*, or by "painting" a water/washing up liquid solution on you can see the bubbles sometimes. * do this at your own risk. My mum lost her absolute $h!t when I did that in their bathtub and left rubber marks in the bath. Got a right hiding for that one. She practically kicked me out the house before the end of summer and back to my university digs
11-03-2020, 01:49 PM | #8 | |
1763
Rep 2,273
