N52, Quick question about ground cable
10-31-2020, 07:08 PM | #1 |
Rep 10
I posted pictures below, first of all, this is a ground cable right? And if so, this is the right one right? https://www.fcpeuro.com/products/bmw...le-12427549393
As you can see In the pictures, I have a bad oil leak and oil has gotten all over it. I am ordering a new valve cover because I’m pretty sure mine has warped, (180,000 miles) getting all new gaskets, already got a new crankcase breather hose, also getting a new Valvetronic Eccentric Shaft Sensor. All genuine BMW brand from fcpeuro. And also want to get that ground cable if that is what that is. Trying to basically get everything I need for my engine and do it all in a day by myself. Doing all this would probably be like 5k at a dealership |
10-31-2020, 07:45 PM | #3 |
212
Rep 354
Drives: 2007 BMW 328xi E92 6mt swap
I think that there are aftermarket cables, so you dont need to spend 50 bucks on one.
10-31-2020, 09:03 PM | #5 | |
1007
Rep 2,109
The one you are looking for is called "interference-suppression band". To make sure you get the correct part go to realoem.com, enter your model and year then engine, engine electrical you will find it there https://www.realoem.com/bmw/enUS/sho...diagId=12_1376 Yours doesn't look too bad. Oil is fine. If it gets crusty green (oxidized copper), then needs replacement. |
johnnyorange58.50 |
10-31-2020, 11:50 PM | #6 |
2717
Rep 4,052
Interference Suppression Band
As others have already suggested, the part# you show is for MAIN Engine/Starter Ground Strap: Large strap beneath vehicle in Starter area or Bottom-Left of engine. Although you don't need to replace an "oil-treated" & hence "rust-proofed" small ground strap, a/k/a "Interference-suppression Band", at the coil area at top-right of engine, if you did elect to do that, the part sells for ~ $23 and is BMW Part# 12427578869.
Here are some examples, including the RealOEM page: https://www.realoem.com/bmw/enUS/par...&q=12427578869 https://www.ecstuning.com/BMW-E91-32...h/12427578869/ https://www.getbmwparts.com/oem-part...42-12427578869 https://www.fcpeuro.com/products?keywords=12427578869 I've always wondered HOW HOT that "Suppression Band" would get if the Main Ground Strap at Starter Failed. ~ Ignition Temp of Oil?? NOT GOOD George |
11-01-2020, 05:27 AM | #7 |
3764
Rep 2,738
Why not just remove it, clean/degrease it, and reinstall? I would take it off the car, spray it with brake cleaner, rinse, and reinstall. Looking at that cable I see no reason to replace it.
11-01-2020, 08:13 AM | #9 |
Rep 10
Thanks everyone for the reply’s. I saw something online about it being a interference-suppression band but wanted to make sure. Definitely going to check my main ground cable now though that you guys are talking about and make sure it’s fine. Will probably just clean the interference-suppression band now that I know. Well wish me luck with my first ever valve cover replacement!
11-01-2020, 08:44 AM | #10 | |
Rep 10
Lol yeah some of my friends like my engine bay, some don’t, I just love customizing my cars lol. This car is the first I’ve ever painted anything in the engine though. I’ll post a better picture of my engine bay and my car. Things I’ve done to my car: AFE power stage 2 intake New oil filter housing gasket, that shit was leaking all over the serpentine belt. (Made the belt fly off and tore it into pieces, lucky it didn’t destroy my engine) Rims Wheel stud conversion (90mm studs) 1 inch wheel spacers in back 1/2 inch up front (bigger wheels soon though so will probably need to get smaller spacers) New fog lights (headlights soon) Trunk spoiler Bc coilovers coming soon. Want to get my engine in good shape before I do anything else though. |
