10-22-2020, 12:36 PM | #1 |
36
Rep 21
M Performance LSD on Xdrive 340i
Hi guys,
Just wanted to inform that I was able to mount the M Performance LSD on my xDrive 340i. All you need is the Diff (Part number: 33108659989) and the rear axles of the non xDrive version (33207597685 left axle, 33207597686 right axle). Only modification that was needed is to grind 10 mm (3/8") of the rear diff mounting point and add 2 10 mm spacer to the front mounting points otherwise the driveshaft would have been too long. Hope it helps for you guys wanting to add the M Performance LSD. One big benefit of this swap is you get the bigger and beefier axles and the bigger Differential too. |
10-22-2020, 02:26 PM | #2 | |
112
Rep 214
10-23-2020, 08:30 AM | #4 |
112
Rep 214
01-10-2021, 05:03 AM | #8 |
82
Rep 203
How is the handling now? Do you feel a big difference in curves ?
340 xdrive 6MT - HJS catted DP - MPPSK - TU HPFP - 550i clutch - VAC monoball control arms - Eibach springs - H&R antiroll bars - AutoSolutions SSK - Brembo HP2000 pads
Corvette C6 Z06 Z07 |
01-19-2021, 04:25 AM | #9 |
36
Rep 21
Handling is great. Driving normally I don't feel any difference. No weird sound nothing. When you drive spirited the DSC is intervening much less, and you feel the back push in curves. On Sport+ it's much easier to do small drifts. On DSC OFF the car drifts nicely out of corners. (Car has KW V3 coilovers, H&R Sway bars front and rear, solid subframe bushings on the rear)
03-02-2021, 06:57 PM | #10 |
38
Rep 65
Drives: 2017 340ix M Perf, 2019 M2 Cmp
Any chances you would have pictures of the diff setup by any chance, I understand what you did but a picture is worth a 1,000 thousand words.
Dan
03-05-2021, 12:57 PM | #11 |
36
Rep 21
RedSectorA37.50 |
03-13-2021, 09:11 AM | #12 | |
36
Rep 21
Here you can see the two fabricated spacer each 10mm and here on the back mounting point 10mm need to be machined of. This differential has not been modified yet: Last edited by Besi5190; 03-13-2021 at 03:16 PM.. |
TheFanatic112.00 RedSectorA37.50 |
03-15-2021, 10:58 AM | #14 | |
36
Rep 21
Part number is 8651301 But it will take some time until I have time to mount it. FYI: There are some M Performance Diffs in the german ebay for crazy cheap. Got the one in the pictures which looks like new for only 600€ there are others which are even cheaper. Tip: Search only with the part number |
10-29-2022, 01:00 PM | #15 | |
Rep 23
While I would love to do this I would honestly not be comfortable shaving the housing for clearance just in case it was over trimmed. Thank you so much and I apologize once again. |
11-16-2022, 06:24 PM | #16 |
430
Rep 1,107
Drives: 2015 BMW 435i Xdrive MSport
Why not just get the diff built by diffsonline.com? I had them build mine for my 435i Xdrive.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
04-20-2023, 12:44 PM | #17 |
Rep 13
Can this be done with the short 3.23 diff for the manuals? Does anyone know if the axle part numbers listed in this thread will work with the the 3.23? RealOEM doesn't specify an auto versus manual diff nor different axles sizes.
05-04-2023, 08:54 PM | #18 |
Rep 21
I'm assuming that those of us with the 6spd can order the linked below with the same housing modifications/axles?
https://www.ecstuning.com/b-genuine-...i/33108659989/ |
12-07-2023, 06:43 PM | #19 |
Rep 1
M-Performance LSD install on a 2016 340ix
Hi all,
Adding to the thread as I just successfully completed this job. For my manual 340i-Xdrive, it needed PN: 33108659988. As mentioned above, it did require purchasing the non-xdrive rear axels (33207597685) and (33207597686) as well. Here are some pics of the diff mounting point when grinding it down 10mm: View post on imgur.com I ended up buying some generic M12x10mm Spacers which worked quite well. Overall fitment is great, really glad to have the stronger axels too. Will see how it holds up over time. I plan to drive it 1000 miles before swapping the fluid to Motul Gear Competition 75W140 |
daveyfx37.00 |
