Brake dust?
04-17-2006, 06:29 PM | #1 |
Deny everything
217
Rep 11,378
Drives: 2006 330i; 2015 X6, S1000RR
Brake dust?
Does anyone have problems with brake dust?
if so, have you installed those covers to protect the wheels from getting all the dust? Thanks |
04-17-2006, 06:45 PM | #2 |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
Don't get the covers, they trap heat in your rotors. Better solution is to apply wax or similiar to your rims and clean them often.
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
04-17-2006, 07:14 PM | #4 |
Moderator
318
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
its part and parcel of BMW ownership..I've come to accept it. Don't let the first few hundred miles bother you, they put out a lot of dust as the pad settles in. Wheel wax is a great idea or just hose it off at least once a week...
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
04-17-2006, 07:17 PM | #5 |
Commander in Chief
37
Rep 1,034
These cars put out an unbelievable amount of brake dust. After washing my car, my wheels are covered with dust within 20-50 miles of driving.
I put a coat of Klasse AIO and SG on my wheels with good results. I can simply wipe them down with a dry towel and they are like new again.
2008 BMW 535i Space Gray, Black Leather, Dark Bamboo Trim| Sport Automatic with Paddles | Sport Package
2008 BMW M5 (gone, but not forgotten) Space Gray, Silverstone Merino Leather, Madeira Walnut Wood Trim | 7speed SMG | All options Mods: Corsa Exhaust | RPI Ram Air Intake | H&R Sport Springs | Rogue Engineering 12mm spacers |
04-17-2006, 09:06 PM | #6 |
it can never be too clean...
163
Rep 1,100
i will be changing my pads within the first week of ownership... done on M3 & X5. i use "rotex gold" dust-free pads. no squeaking and 95% dust free imo. the pads are the same as the e46 M3 front & rear.
the dealer knows i use them and is ok with it (really depends upon dealer). heck... they even replaced my rotors on my X5 once under warranty. |
04-18-2006, 10:14 PM | #7 | |
12
Rep 715
E46 325xi Oxford Green/Sand Leatherette/Myrtle Wood Auto ZCW - Retired
E90 330xi Mystic Blue/Black Leather/Aluminum 6sp Manual ZSP/ZPP/ZCW/CA - Retired F22 M235i Mineral Gray/Red Leather/Aluminum 6sp Manual ZPP/ZTP |
04-19-2006, 10:02 PM | #8 |
fresher den you
34
Rep 986
Drives: 2004 x3
my e90 has about 11,000 miles on it and my brake dust isnt too bad ne more. it was bad tho when i first got the car. i usually wash my car every other day so the brake dust doesnt get too bad
04-19-2006, 10:14 PM | #9 |
Rep 137
I assume the aftermarket brakes have wear sensors--at least, they did on VWs.
Are the wear sensors on the E90s wires that touch the rotor and complete a circuit when the pad is worn (and the CBS just guesstimates a mileage based on brake usage)? Or do they incorporate a more advanced sensor? How does the use of aftermarket pads affect the CBS calculations? |
04-19-2006, 10:53 PM | #10 |
155
Rep 6,158
aftermarket pads have the same sensor as stock pads, the sensor isn't a part of the pad but instead it's a separate item that snaps into the pad
it's a wire loop, the when worn down enough the wire wears through and breaks as the pad becomes low once the wire's broken the light turns on not sure about the miles left calculations the computer makes though?? |
04-21-2006, 09:39 PM | #11 |
Rep 18
I bought a set of disc brake covers thinking I could reduce the dust from accumulating on the rims but the dealer told me that it would add additional road noise and possibly overheat the rotors. The manufacturer of these covers claims that they have a patented design that allows the heat to escape through the vents. Since the run flats are already noisy, I felt I didn't need anymore noise coming from the rotors and that was that. If you are interested in the covers, I have them for sale and they are brand new. I had the dealer put on Xzilon clear coat protectant on the car, he also put them on the wheels and that has helped reduce the brake dust buildup. A suggestion would be to replace the existing brake pads with ceramic pads. They are suppose to last longer and lowers the dust output. Check out Hawk Performance Ceramic Street Brake Pads at http://www.bimmerworld.com/html/hawk...brake-pads.htm
