10-18-2020, 09:29 AM | #1 |
Rep 13
Unknown blue light in my 530e
Apparently there's no active warning anywhere else, apart from this icon near by edrive battery gauge.
Do you know what it means? Thanks |
10-18-2020, 11:28 AM | #2 |
648
Rep 632
Baffling. Your question intrigued me so I looked through my 540xi owner's manual and could not find this symbol. Googled BMW warning lights and got a list of 68 from BMW of Escondido but it did not show your symbol. They did say the following:
BMW Warning Lights Presented by BMW of Escondido Some of these warning lights will appear when you first start the car, along with how many miles you have until your next scheduled service. • Red warning lights are associated with danger, and there is a serious situation which must be checked out before continuing. • Orange and yellow warning lights are less critical, but something is wrong and should be resolved as soon as possible. • Green or blue warning lights indicate that your vehicle has a technological feature enabled. I also went further and Googled "BMW 530e warning lights" and got lots of responses with lists and pictures of lots of warning lights, including one that had 308 on it. I did not see your "car with a thermometer" symbol however. If I had to guess it may have something that has to do with interior car temperature, perhaps suggesting some ventilation feature is active? I suggest checking in with your dealer service guys and let us know the answer. Good luck.--Bob
2019 540xi M Sport, Carbon Black/Cognac, 2014 328xi, 2016 Corvette Z06; Previous:2010 BMW 535xi M Sp, 2008 335xi, 1998 M3 Sedan,1980 528i, 1977 320i, 1976 2002
10-18-2020, 11:48 AM | #3 | |
Rep 13
Thanks (I also spent part of the afternoon googling...) I've already asked the dealer, and will share my findings in this thread. Thanks Last edited by TiagoRibeiro; 10-18-2020 at 03:42 PM.. |
10-18-2020, 01:32 PM | #5 |
Rep 13
10-18-2020, 03:22 PM | #6 |
2788
Rep 5,104
10-19-2020, 03:29 AM | #7 |
Rep 13
Adding my experience from this morning, this symbol disappears after using the combustion engine for a bit. When it disappears, it’s replaced with the indication “eBoost”.
Also found this in another forum (X5 discussion thread): “The full drive power may not be available for approximately 30 seconds after starting the combustion engine. In this case, the vehicle will not accelerate as usual. The maximum drive power can be utilized as soon as eBoost is available.” I’m starting to wonder if this is only an indication that eBoost is still not available… |
10-19-2020, 03:39 AM | #8 |
2026
Rep 2,946
Drives: 2020 BMW 530xe
This matches the symbol that shows next to my battery if it is colder outside and I don’t precondition first. The battery needs to be warmed up to temperature. I can’t remember it showing up in the cluster where eBoost shows up, but you have the LCI I presume.
01-01-2021, 02:30 PM | #10 |
109
Rep 176
Also intrigued about this symbol and after 30 mins of googling, nothing came out.
Did you (or anyone) had any feedback from the dealer? I guess this light/symbol might indicate that the electric climatization is being used, as opposed to the traditional AC system that uses the thermal emgine for running. Nevertheless, I would like to be sure about this! Regards |
01-01-2021, 02:52 PM | #11 | |
2026
Rep 2,946
For my Pre-LCI MY2020 530e I'll get a similar symbol near my battery charge meter when the battery is too cold to let me know the system won't run on eDrive until it has warmed the battery (or cooled it in too hot temps). My guess is the LCI has this up top due to its extra overdrive in eBoost mode as I mentioned earlier. Meaning since the battery is too cool (or warm) to allow the EV motor to run the symbol is letting you know that the extra HP you have access to via this functionality is unavailable until the battery is brought to temp. |
ted99242.00 |
01-01-2021, 04:08 PM | #12 | |
109
Rep 176
01-01-2021, 04:47 PM | #13 |
2026
Rep 2,946
I don't have the LCI so I can't say the exact limitations of the system. The manual should clarify it though.
01-29-2021, 11:35 AM | #14 |
284
Rep 202
Drives: 2023 BMW 760xi, 2024 BMW 530i
I get that symbol randomly, even if everything is at operating temperature. Mine shows up where the Battery DTE is. Instead of it showing the range, it will show that light. My engine comes on and the A/C stays warm until the light goes off.
cwiginton42.50 |
01-31-2021, 07:32 PM | #15 |
122
Rep 565
I think it just means that the eBoost feature is not available temporarily due to the battery not being in the ideal temperature.
I started seeing the symbol when it got cold outside during winter. What is strange is that the symbol does not go away even after driving a longer period of time... |
02-03-2021, 10:29 AM | #16 |
648
Rep 632
I am surprised that no one at BMW has been able to explain what this is. One would think that if there is a warning light on, one should do something about it, but it is hard to take action without knowing what it means. --Bob
02-09-2021, 04:02 PM | #17 | |
109
Rep 176
Still wondering how long it will take until someone confirms what that symbol means. |
02-09-2021, 04:10 PM | #18 |
2026
Rep 2,946
02-09-2021, 06:07 PM | #20 |
2026
Rep 2,946
That's odd.
But does a Check Control Message appear to give details? When I got this on my MY2020 it will let me know that the HV battery is being heated or cooled in a check control message and will be available once it has done so. Perhaps that will clarify what isn't available and why. I am still sure it is HV battery isn't at operating temp for eBoost. |
02-10-2021, 06:59 PM | #22 |
2026
Rep 2,946
Does it come up only when you're in "XtraBoost" mode? My understanding is that mode is only turned on in sport mode? But I don't have an LCI so I'm not sure. As I am convinced it has something to do with the extra demands for that mode.
Does the car tell you when that boost mode is and isn't available? My MY2020 just shows "Boost" there where it will use the EV motor to deliver the rest of the car's HP. I assumed they added extra details to help you know when you're accessing the enhanced mode in the LCI. |
