F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Wagner 200 cel cat
Extreme Powerhouse
      10-16-2020, 08:25 AM   #1
328iking
24
Drives: 328i
Wagner 200 cel cat
Who has fitted a Wagner 200 cel cat to their n20 328i?
Did you find that the gearbox bracket does not line up and therefore is only secured via one bolt (top one)?
Pic is of oem but that bracket is not secured.
      10-17-2020, 07:22 AM   #2
328iking
24
Drives: 328i
As you can see. Doesn't line up
      10-18-2020, 05:27 AM   #3
canman111
17
Drives: F30 328i RWD
2014 BMW 328i  [0.00]
Hey,
I've got the same DP on my n20.
It's been a while since I installed mine, but if I remember correctly, I used a bolt and nut that I had lying around the garage. I don't know if Wagner actually provides one because my box was empty. But the bolt was a bit slimmer than the factory DP one and I had to "wiggle" and sort of jam it in. Then I used loctite on the nut because of vibrations that I was worried about loosening the nut.
Good luck with your install.
      10-22-2020, 06:26 AM   #4
twistedmunky
Australia
Drives: BMW 328i F30
The guy who installed my Wagner downpipe has no issues with it at all.
      11-04-2020, 04:52 PM   #5
328iking
24
Drives: 328i
Some better pics
f30post
