Bimmerpost
4 Series
Technical Topics B48 4-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications IND | Eventuri G20 3-Series (B48) Carbon Intake System Introduction
      10-14-2020, 11:20 AM   #1
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
AVAILABLE FOR PRE-ORDER NOW
Eventuri’s wizardry continues to amaze amidst BMW’s new turbo era—their new G20 (B48) intake has been developed to provide the turbo with a less restrictive flow path whilst maintaining low inlet temperatures.
While retaining heat within the exhaust is a fantastic tool to optimize the thermal efficiency of a turbo, it is detrimental for overall engine performance on the intake side. Eventuri has once again implemented a sealed system with a gold reflective heat shield to help combat heat, but the G20’s design features something we haven’t yet seen from the UK-based outfit: they have incorporated a clever secondary feed via the wheel arch area. Airbox volume has also increased while bearing in mind a recess for potential strut braces—now that’s attention to detail.
THE AIRBOX FEEDS: EXPLAINED
The stock airbox draws air from a single duct which extends to the front bumper area. During development we identified another area to draw cold air from which was a gap between the wheel arch and the chassis on which the airbox sits. To utilize this feed, we extended a scoop at the back of our design which protrudes into the wheel arch and can even be seen after installation behind the front wheel. This second feed allows the turbo to draw from a larger area therefore reducing the restriction.
TURN UP THE VOLUME
Volume increases in the intake tube as well—Eventuri’s smoother flowing tube boasts a 4.3” internal diameter (versus 3.2” OE) that tapers down to match the turbo inlet. This equates to a massive 82% increase in cross sectional area over stock while also eliminating the turbulent flow path inherent to the flexible, factory accordion tube. Eventuri’s version also features a CNC machined fitting for the temperature sensor and breather adaptor.
As a note to highlight, the G20 B48 OEM airbox system was updated in cars built after November 2018. Cars with production dates after November 2018 feature a temperature sensor inside the inlet tube. Prior to this date, all airbox systems had an airflow sensor, so it is imperative to understand which intake you may require. For all intents and purposes, V1 denotes the pre-November 2018 cars and V2 represents post.
BESPOKE CONE FILTER: EXPLAINED
Our cone filter is made from a non-woven mesh material which is double layered and is ISO tested to ensure that filtration is in line with OEM standards. The filter is cleanable and very stable at high temperatures with the base material being Urethane. The filter incorporates and internal flow guiding cone to help aid the airflow to converge while reducing the possibility of a stagnation point in the middle of the filter space. The filter medium has a significantly larger surface volume than the stock panel filter.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      10-14-2020, 12:15 PM   #2
jrs_nauman
Drives: 2020 330i sedan
Is this intake also compatible with the B46D engine version?
      10-14-2020, 12:39 PM   #3
IND-Distribution
BMW obsessed
9587
Yes, the OE filtered air-pipe and airbox are the same across B46 and B48 variants.
      10-14-2020, 02:25 PM   #4
Knifeedge2k1
153
Drives: BMW G30 520i 2019
Will you guys be making a similar intake for the G30?
      10-15-2020, 08:20 AM   #5
MassBimmer
MassBimmer's Avatar
No_Country
306
Drives: 2023 i4 M50
2009 BMW  [9.24]
Dare I ask the pricing on this?
      10-15-2020, 10:16 AM   #6
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
24193
Drives: 07-335/12-328/18-M4/21-M4CP
Looks great
https://x-ph.com/sale/
Phone number 702-494-9435
      10-15-2020, 10:18 AM   #7
mike@x-ph.com
24193
retails at $1395
      10-20-2020, 05:14 AM   #8
Knifeedge2k1
153
Originally Posted by mike@x-ph.com View Post
retails at $1395
lol wut ?
      10-20-2020, 11:48 AM   #9
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
Originally Posted by Knifeedge2k1 View Post
lol wut ?
Yup. Eventuri CF systems go for $1000+ for other cars. I'm not surprised at the almost $1400 for the G20.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      10-20-2020, 12:23 PM   #10
OM3RTA
391
Drives: 330i M Sport, Audi A3 2.0 TDI
Are there any vids with one of these installed in a G20?
      10-20-2020, 12:58 PM   #11
Don76
171
Drives: BMW 320i M-Sport
They should follow Armaspeed and make two variants. One carbon, one alloy.
It would half the cost for those of us who rarely open the hood
      10-27-2020, 09:35 PM   #12
Avaley
Avaley's Avatar
732
Drives: f32 430ix & 982 GT4 PDK
I love this intake, but I feel like at $1400 for just an intake that will maybe give you 5hp at that price per performance gain you might as well have spent the $6500 more assuming no displacement taxes for the B58.
edit: tbf carbon fiber is just plain expensive...this would make more sense on a $100k M2CS imho.
      10-27-2020, 09:36 PM   #13
Avaley
Avaley's Avatar
732
I would love to see a dyno for this, I'm expecting it to outperform other options given its premium pricing.
      10-30-2020, 09:23 AM   #14
mike@x-ph.com
24193
You are paying for the cosmetic upgrade not the HP increase, you can get the same gains with much cheaper intakes.
It'll defintely make your car stand out though, the nicest looking intake in my opinion
Appreciate 2
VipinLJ1941.50
Avaley732.00
g20
