UUC DSSR Fitment
10-10-2020, 06:20 PM | #1 |
Rep 3
UUC DSSR Fitment
While trying to install the DSSR it felt like the ends of rod would not be able to clear the shifter rod joint. So I ended up putting on the original rod for the mean time.
The UUC DSSR was purchased at ECStuning with the part number: DSSR177-B, saying that this will fit my car. 2011 E90 328i Sedan. Is it possible that I may have received a bad rod or that they just lied about fitment? Has anyone else experienced this problem or found a way to make this rod fit over the rod joint? |
10-10-2020, 06:25 PM | #2 |
3764
Rep 2,738
Yes I had the same issue. I could not get the rod installed it would not fit at either end, shifter or tranny. Plus when placed next to my oem shift rod the dssr was shorter so it would have moved my shifter offcenter in the boot.
I thought I got the wrong part I emailed and they confirmed correct one. So I ended up returning the dssr because it simply didn’t fit. Then there was the battle with UUC for a refund. They were non responsive to questions when I asked if they received my return, when would I get my refund, etc. I sent 4 emails over 2 weeks asking what was going on. After 14 days I ended up doing a chargeback on my card and ended up only losing out on return shipping. I’ll never buy another product from them again. Lucky you bought it from a reputable dealer and not direct!
10-10-2020, 06:48 PM | #3 |
Rep 3
Thanks for the reply! |
10-12-2020, 01:06 PM | #4 |
883
Rep 1,413
Totally better off going to an Indy. I had my pal in Chesapeake do a custom dssr. No issues! Hope this helps. Maybe you can take a salvaged oem unit and they can match everything up in your creation? Unless you're a welder, then I apologize. :,)
See you, space cowboy.
Supercharged |
