Serpentine Belt Tensioner Bolt Replacement?
09-25-2020, 01:09 PM | #1 |
Rep 11
Hey guys,
One thing lead to another and I ended up reusing the aluminum bolt for the belt tensioner twice as I had some issues taking out the pin from the new tensioner while setting the tension on the belt. Before I realized the pin needed to be removed I took off the tensioner and reinstalled it thinking something else was the issue as the guide I was following did not mention what to do with the pin. So the new aluminum bolt was torqued to spec then removed and torqued again. Now I am wondering if I should replace it with a new bolt. So is it possible to take out the aluminum bolt from the tensioner that is already installed and the pin removed then replace with new bolt? Or would I have to purchase a new tensioner since the pin was removed? Thanks great forum btw! |
09-25-2020, 02:51 PM | #3 |
1439
Rep 2,529
Drives: 2011 328i Wagon
DEFINITELY get a new bolt. Given the risk of having the belt come off and get ingested through the front crank seal, I would not even drive the car until you replace that bolt. It's a torque-to-yield bolt, so if you torqued it to spec the first time it's done.
As the other fellow said, just put the pin back in (or a nail or whatever if you don't have it) then take it off and replace the bolt.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
09-29-2020, 01:36 PM | #4 |
Rep 11
Thank you for the help I was able to replace the bolt after putting the pin back on tensioner.
Just wondering what exactly does the pin do? If you remove tensioner without putting the pin what happens? |
