09-23-2020, 06:26 PM | #1 |
11
Rep 29
Top off engine coolant AGAIN
Sorry if this topic been talked about before. This is the second time I have to do this, got me worried. Service guy told me this is normal for car to top off coolant. I said maybe for BMW is. He didn't like that at all. Anyway, hope this is "normal " for BMW.
Anyone have been through this? It's normal right? My car is 540i xdrive 20018 Any input would be much appreciated |
09-23-2020, 06:28 PM | #2 | |
332
Rep 736
On a long trip, I carry coolant and a quart of oil in the trunk.
2017 540i M, Carbon Black/Mocha, 20 in. on Michelin PS4S, CF Mirrors/Rear Spoiler
2009 328i 6 spd stick, Crimson Red/Sport Suspension, Bavsound Stage 1, 2 Former BMWs: '79 320i, '84 325e, 2000 328i, 2014 535i |
09-24-2020, 03:27 AM | #3 |
185
Rep 301
Its a known issue with the B58... I don't think anyone has a conclusive answer but equally it doesn't seem a serious issue. Some have reported leaking water pumps or hoses, or expansion tank caps that don't quite seal correctly, but there doesn't seem to be a consistent pattern. Mine loses a tiny bit every now and then, but the amount disappearing is miniscule (for now). I am intrigued to find out where it is going though!! It baffles me how liquid can escape from a supposedly sealed system and for this to be deemed "normal" but there we go!
09-24-2020, 03:33 AM | #4 |
2783
Rep 5,095
I'd just make sure you have it recorded with the dealer in case of issues that may occur later, especially if just the warranty has expired!
Worth using a torch to see if you can find any in the engine compartment. In my case it was faulty reservoirs (yes there are 2) . Tell tale signs were seen with a whitish residue beneath them. Mine were replaced under warranty and no issue seen since. |
09-24-2020, 07:13 AM | #5 | |
Alpine White|19" Wheels|
33
Rep 64
https://www.newtis.info/tisv2/a/en/g...ooling/1HZe3We |
09-24-2020, 09:06 AM | #6 | |
332
Rep 736
When I returned home with a Cert PreOwned 540i M, I looked at my driveway and saw the drip, drip, drip. Opened hood, saw liquid below coolant and expansion tank. Took it back next morning, showed SA the leak and we both got on our knees and he saw it. Opened trunk, he saw some small squirting from expansion tank. Covered under warranty. In my 2000, 2009 3 series, and 2014 535, they all needed filling occasionally. Even the owner's manual says you need to top it off occasionally. As to yours going so low, I would never have it go too low - the biggest threat to an engine is heat and friction (my undertanding). Keep it at the minimum at least. Take a pic before you fill it and take it to SA. I took a video of the drip, drip and expansion tank area and texted it to SA before I came in.
2009 328i 6 spd stick, Crimson Red/Sport Suspension, Bavsound Stage 1, 2 Former BMWs: '79 320i, '84 325e, 2000 328i, 2014 535i Last edited by Desmond79; 09-24-2020 at 09:12 AM.. |
09-26-2020, 08:35 AM | #7 | |
33
Rep 64
09-26-2020, 11:42 PM | #8 | |
332
Rep 736
10-17-2020, 11:52 PM | #9 |
163
Rep 321
My 2018 540i xDrive also exhibits loss of coolant. It is a very minuscule with about the amount between the minimum and maximum fill line in the coolant expansion tank every 10k miles or so. I purchased it as CPO with about 40k miles and it now has about 60k miles on the odometer.
The other day I was tinting my fog lights which required removing the bumper and wheel liner. In doing so, I discovered that the B58 has a displaced/remote radiator on the bottom front right of the car behind where the passenger side (LHD car) fog light would be. Upon investigation on the parts catalog, it looks like this remote radiator connects directly to the main high temperature radiator via two relatively long coolant hoses. I spotted telltale signs of a slow leak due to the splash guard being slightly discolored from dried up coolant. I suspect one of the fittings (lower one) is slowly seeping coolant out when the system is up to operating temperature/pressurized. I'm not sure if I should bring this up to the dealer, but for now I think I will just keep an eye on it. The rate of coolant loss hasn't noticeably increased in the past 20k miles of my ownership. To anyone else exhibiting slow coolant loss, it might be worth checking out that area to see if there are signs of any leaks. It's quite easy to access...just raise/jack up the front right corner of the car and remove the front right wheel liner. From there, you should be able to see the remote radiator and the splash guard below it to determine if there are any leaks or not.
2018 G30 540i xDrive M Sport | Carbon Black Metallic | KW V3 Coilovers | F90 Suspension | F90 Brakes | 20" HRE FF10 Liquid Black Wheels | Michelin Pilot Sport 4S Tires | Ivory White Dakota Leather | Carbon Fiber Trim | Executive Package | Bowers & Wilkins Diamond Surround Sound System | JL Audio 12W6v3 and XD600/1v2 | Ceramic Controls | BM3 Stage 2+ E50 ECU Tune | xHP Stage 3 TCU Tune | Dorch Stage 2 HPFP | MST Cold Air Intake | FTP Chargepipe | AA Catted Downpipe | Remus Catback Exhaust
