BMW X5
      09-23-2020, 12:52 AM   #1
menace33
Serbia
47
Drives: 2020 BMW X5 45e
X5 45e vs 40i petrol engine
Hi all,
I was just wondering is there any reason behind the difference in power between petrol engine in 45e and 40i? As per Wikipedia, they both have B58B30M1 engine, but in 40i it produces 340PS and in 45e only 286PS. Are these engines completely the same or is there maybe any difference in turbo chargers?
Even when you take a look at https://en.m.wikipedia.org/wiki/BMW_B58 there is no word about 286PS version in 45e.
Any thoughts?
      09-23-2020, 04:26 AM   #2
Rosso77
Belgium
26
Drives: X5 45e
same engine, just down sized to 286hp.
that's why remapping the 45e gives you these hallucinant figures:
https://www.br-performance.be/en-be/...018/10815-45e/
X5 45e
S1000R
      09-23-2020, 08:39 AM   #3
X5 45e
No_Country
1091
Drives: BMW X5 45e
Originally Posted by menace33 View Post
Hi all,
Any thoughts?
Some parts have changed (stronger) to accommodate to accelerations with a cold engine. And probably they downturned
The engine for the same reason. I don't know about the turbo.
I found out this weekend that if I put my car is sport directly after turning it on, it is at working temperature after 2 minutes. Is this as fast as an fuel only car? Or is an supplemental heater heating up the oil faster?
      11-13-2020, 09:39 AM   #4
philooo
82
Drives: porsche
I'd love to know the more exact difference between the 2 engines...in order to see how safe it would be to tune the engine... it is possible they detuned it to comply with CO2 regulation for that car, and that a chip is all it takes to get the power back...
      12-06-2020, 09:49 PM   #5
jad03060
3159
Drives: X5 45e
In normal hybrid mode, you have more Hp than the 40i, and the torque is higher because of the electric motor.
My guess is that the detuning was done for efficiency reasons and the gearing as well. The manual doesn't seem to list the final drive gearing, so I don't know if they're different. Because of the higher torque, the ICE and hybrid could be different.
      01-03-2021, 05:39 AM   #6
ianfp
ianfp's Avatar
144
Drives: X5 40D M Sport
What I understood is that in the 45E there is a single turbo, but the 40i has a twin turbo. Not sure if this is right.
      01-03-2021, 07:38 AM   #7
45e X5
Ireland
39
Drives: X5 45e
Nope 45e also has the twin turbo engine. It's just a revised version of the 40i engine detuned
      01-03-2021, 07:58 AM   #8
philooo
82
Drives: porsche
when you think the gas engine may need to start stone cold at any time, the engine had to be tuned specifically to avoid premature wear.
2021 45e journal
      01-03-2021, 08:05 AM   #9
FloridaM5
FloridaM5's Avatar
461
Drives: 2021 M3 Comp RWD
  [5.83]
Both models are single turbo. They are both twin scroll, single turbo setups.
      01-03-2021, 01:11 PM   #10
45e X5
Ireland
39
Drives: X5 45e
I stand corrected 👍 indeed a single turbo.
This is a very good article explaining it.
https://www.bmwblog.com/2020/09/02/h...n-power-works/
      01-03-2021, 01:56 PM   #11
FloridaM5
FloridaM5's Avatar
461
  [5.83]
Oddly named setup by Bmw for sure
      01-03-2021, 07:56 PM   #12
jad03060
3159
Drives: X5 45e
While BMW does have some engines with two turbos, those with one are usually referred to as twin-scroll, and have several modes so that they spin up faster so the torque is more even across the range versus a smaller one that would not peak out until turning faster. Older designs were really peaky, not providing much boost until it got above a certain speed, then it was somewhat radical.
xbimmers
