BMW M2 Forum > BMW M2 CS Model > I wonder how well the M3/M4 HAS would work on the CS
      09-20-2020, 02:38 PM   #1
M Fifty
844
Drives: M2 & 330CI
Just a thought...
      09-20-2020, 03:27 PM   #2
Acetech
Acetech's Avatar
219
Drives: 03 M3. 98 M3. 11 1M
I think it's the same kit as the M2.
I will be installing it shortly after the car arrives.
      09-20-2020, 05:00 PM   #3
M Fifty
844
Drives: M2 & 330CI
Nope. M2 used M Performance suspension (rebadged KW V3), while M3 and M4 just use Height Adjustable Springs - hence the name - with the existing electronically controlled dampers.
      09-20-2020, 05:04 PM   #4
Higgs Boson
In the Details
1810
Drives: Yes
2020 AMG GTR  [0.00]
2022 R8 Quattro Spyder  [0.00]
2023 X5M50  [0.00]
2023 718 Spyder  [0.00]
2024 Silverado  [0.00]
2024 Civic Type R  [0.00]
https://ind-distribution.com/collect...ompetition-f87
Acetech218.50
      09-21-2020, 01:56 AM   #5
M Fifty
844
Drives: M2 & 330CI
That's the KW. The BMW HAS kit however...
      09-24-2020, 06:41 PM   #6
robbys3m3
1941
Drives: M3's
So to be sure...what kit do we think will work?
      09-24-2020, 07:12 PM   #7
Acetech
Acetech's Avatar
219
Well the link above clearly indicates the single part # KW HAS kit fits F80-82 & F87M2
Considering that I wager the F80/82 M performance HAS kit ( manufactured by KW for BMW) would likely work on the F87 but why bother when the KW HAS kit is directly approved for F87 M2 and significantly less expensive than M performance kit.
      09-25-2020, 02:07 AM   #8
M Fifty
844
Drives: M2 & 330CI
The reason the F80-82 BMW HAS kit apparently works on those models but not the F87 is supposedly the active dampers on the former that the latter lacks.
The CS has the active dampers, and hence the question.
HTH
      09-25-2020, 06:34 AM   #9
Higgs Boson
In the Details
1810
Drives: Yes
2020 AMG GTR  [0.00]
2023 X5M50  [0.00]
HTH
if you click the link and look at the url, it says M2-cs
if you scroll down and see the list of compatible cars you will see M2, M3, M4 and then if you consider what that means, when the M3 and M4 already had adaptive suspension, the point becomes, yes, the same kit will work on the M2CS with adaptive suspension.
what do you think is special about the adaptive suspension that makes it need different springs?
      09-25-2020, 06:38 AM   #10
cncmastr
cncmastr's Avatar
1582
Drives: E30 M3 Cecotto, F85, G05, G07,
2018 X5 M  [0.00]
2020 M2 CS  [10.00]
2005 BMW X5 4.8is  [0.00]
2006 BMW M3  [0.00]
The real issue is the front shocks on the f87 are not the same on the f8x.
      09-25-2020, 06:41 AM   #11
M Fifty
844
Drives: M2 & 330CI
I don't think it needs different springs, more that the adaptive dampers on the F80-82 can apparently cope with the HAS kit, whereas the non-adaptive dampers on the F87 OG and LCI struggle.
So, noting that the CS has adaptive dampers I was wondering whether the F80-82 HAS kit would work on that car even though it apparently doesn't on the OG and LCI.
I am aware of the KW HAS kit, and that it is listed as having broader application than just the F80-82.
      09-25-2020, 06:42 AM   #12
Higgs Boson
In the Details
1810
Drives: Yes
2020 AMG GTR  [0.00]
2023 X5M50  [0.00]
https://www.kwsuspensions.com/kw-sus...253200anu.html
Notes
91: Front and rear height adjustable (front and rear springs with threaded height adjusters). Stock shock absorbers including electronic controls are being utilized.
      09-25-2020, 06:45 AM   #13
M Fifty
844
Drives: M2 & 330CI
The rears aren't the same either though.
      09-25-2020, 09:47 AM   #14
MDuckie
MDuckie's Avatar
93
Drives: M2CS
I was under the impression it has the same exact suspension as the M4?
      09-26-2020, 06:01 PM   #15
M Fifty
844
Drives: M2 & 330CI
The springs and dampers differ, but otherwise yes.
      09-27-2020, 05:31 AM   #16
Racer20
1030
Drives: F80 M3, 228i THP, E46 ZHP
Spring rates are partially decided based on a cars wheelbase. F80 springs will be a few percent off for an F87 in terms of front to rear balance. Will you notice? Maybe. Would I? Yes.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
      09-27-2020, 09:57 AM   #17
Acetech
Acetech's Avatar
219
OP, where are you getting your information from?
I haven't yet checked the ETK parts catalog at work to see I'd the CS is listed yet, realoem doesn't list it yet.
But here is a screen shot of a previous post here stating that the M2CS uses the same springs front and rear as both OG &C M2. It also indicates the shocks/struts are the same part number as F80-82-83 with EDC.
      09-28-2020, 12:31 PM   #18
M Fifty
844
Drives: M2 & 330CI
I think we might be talking at crossed purposes, but this is why I think the parts are different on the M2 compared to the M3/4:
https://www.realoem.com/bmw/enUS/par...&q=31312289535
https://www.realoem.com/bmw/enUS/par...&q=31312289536
https://www.realoem.com/bmw/enUS/par...&q=31337853270
https://www.realoem.com/bmw/enUS/par...&q=33522289537
https://www.realoem.com/bmw/enUS/par...&q=33537853275
      10-21-2020, 01:58 PM   #19
robbys3m3
1941
Drives: M3's
I assume we don't have any more clarity yet on what springs may work for the CS application right?
2020 M2 CS, 2018 M3 CS, 2016 M4 GTS, 2013 M3 LRP, 2011 1M, 2011 M3 GTRS3, 2004 M3, 2002 M3, 2000 M Coupe, 2002 M5, 1997 M3, 1988 M3, 2022 STO, 2020 Urus, 2022 TRX, 2022 392, 2021 SVJ, 2018 Performante, 2013 Gallardo 550-2, 2012 Gallardo STS, 2018 R8 RWS, 2012 R8, 2017 G550 4X4^2, 2015 GT3, 2015 Continental GT3R, 1971 Bronco
      12-20-2020, 07:23 AM   #20
Wah
IG@i.am.wah
Wah's Avatar
2779
Drives: M2 CS
Did you ever determine if the F8x MP HAS kit would work? If I trade in my M4 I may pull the HAS kit if it can be reused.
      12-20-2020, 11:41 AM   #21
robbys3m3
1941
Drives: M3's
i have ordered the KW HAS and plan to try it right when I get my car
Hedoniste3834.00
      12-20-2020, 12:39 PM   #22
AlpsRider
AlpsRider's Avatar
2865
Drives: M2 Competition, LBB, 6MT
I installed the Dinan springs on my M235i with adaptive suspension. I know it's not an M car, the programming of the adaptive suspension sometimes got it wrong with the springs. For instance driving on the freeway at 70 mph it became very stiff and jiggly. I remember on some BMWs the tuners came out with a hack for the adaptive suspension to take into consideration the springs. Sadly they were never able to hack the adaptive suspension on the M235i. One of the main reasons I sold the M235i was because I could never get the suspension right.
m2
