09-14-2020, 04:52 PM | #1 |
12
Rep 17
Installed a gloss black rear diffuser from eBay on my 2017 Bluestone Metallic 540i M-Sport.
Install was a bit confusing at first (trying to figure out where all the tabs are- there is a lack of in-depth videos out there on the G30), but overall it was very simple. Took me 1.5 hours, but in hindsight I could've done it in under 30 min. Diffuser is ABS plastic and cost $180 from New Jersey. Only has 4 holes for screws that come included with the diffuser. Remove 7-8 OEM screws and pull on the corners until tabs pop out, then pop in the new diffuser. Fit is 9/10, not 100% precise but nothing really noticeable. Kick-to-open trunk function still works with this diffuser, surprisingly. The difference between the OEM M-Sport diffuser and this gloss black aftermarket one is night and day, matches the gloss black trim around the entire car. Will be installing gloss black 540i decal as well, and considering black exhaust tips... any recommendations on the tips? |
09-14-2020, 10:27 PM | #3 |
73
Rep 199
Yes who was the seller and any other install tips would be appreciated. Would love this for my 2017 Graphite Metallic 540i M-Sport!
Nice job, she looks a lot better!!! |
09-15-2020, 12:46 AM | #4 |
12
Rep 17
Gloss Black Rear Diffuser Install (G30 540i M-Sport)
I've sent you a PM for the seller.
Thanks! I'm glad to hear some affirmation for my decision to buy this bad boy, would look great on a Dark Graphite Metallic! That was actually my first-choice color for the 5er, had Mineral Gray Metallic on my 328i. BMW makes a sleek gray color, but had to settle for the Bluestone Metallic instead. I haven't seen too many Graphite Metallics, do you have any pics of yours? |
09-15-2020, 05:38 AM | #5 |
1616
Rep 2,274
Looks great! Looks so much better.
Did it come as one piece or two? I want to do the same on mine. Can you also PM me the seller's link please?
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
nyu9812.00 |
09-15-2020, 05:43 AM | #6 |
1616
Rep 2,274
I looked at getting OEM black chrome tips for the exhaust. They are from the sport model which we don't have in the UK.
The tips are £102 each. Bit steep but still in 2 minds. The other alternative someone recommended to me was using Foliatec Exhaust Spray Paint. Looks easy enough to do and seems to be long lasting.
IG: project540ix
09-15-2020, 05:48 AM | #7 | |
201
Rep 221
Drives: 2023 M5 Competition
09-15-2020, 06:12 AM | #8 | |
60
Rep 627
09-15-2020, 09:37 AM | #9 | ||
12
Rep 17
09-15-2020, 09:44 AM | #10 | |
12
Rep 17
The diffuser came in one piece, in a long box. Package includes painted Tow Hole Cover and 4 screws. I have to say that the wrapping was not brilliant... a thin sheet of foam over the diffuser and covered in a thin plastic bag. It didn't sustain any damage but the box had a tear. This shouldn't deter you but just something to keep in mind about the packaging. Perhaps you can request the seller to send it in extra packaging, he is quick and responsive. |
Junebug851616.00 |
09-15-2020, 02:38 PM | #11 | ||
1616
Rep 2,274
Will take a look at the link tonight
IG: project540ix
09-15-2020, 10:28 PM | #13 |
73
Rep 199
09-15-2020, 10:52 PM | #14 | |
73
Rep 199
nyu9812.00 |
09-16-2020, 09:10 AM | #16 |
36
Rep 32
Drives: '17 540 M Sport
Looks great! I need to do this on mine for sure...thanks for sharing.
Did you have to take off the reflectors from the OEM diffuser and put them on this one? Wondering if that was a pain to do. Thanks |
nyu9812.00 |
09-16-2020, 12:24 PM | #17 | ||
12
Rep 17
How is the Kenzo coating? Did you get it done professionally? I've been getting quoted for Ceramic Pro and Xpel Film wraps at an installer near me, but I don't know much about Kenzo. |
09-16-2020, 12:28 PM | #18 | |
12
Rep 17
Yes, just use the OEM reflectors that you have. That was actually the easiest part of the whole install. There are three squeeze tabs behind the reflector that you pop out and then simply pop back into the holes of the new diffuser. Takes about 30 seconds. It would also be a good opportunity to get smoked or painted reflectors if you're into that |
Junebug851616.00 |
09-16-2020, 08:56 PM | #19 | ||||
36
Rep 32
09-17-2020, 01:21 AM | #20 | |
73
Rep 199
If you want to check authorized Kenzo installers in your area you can check them here https://iglcoatingsusa.com/igl-approved-search/ Good luck and let me know what you decide on. |
09-17-2020, 01:27 AM | #21 | |
73
Rep 199
10-28-2020, 04:50 AM | #22 |
1616
Rep 2,274
Just received my new Gloss Black diffuser. As it comes in 2 pieces, there are some fixings that came with it.
I think the 2 smaller pices go on the ends of the bottom piece but can't work out where the 3 taller pieces go... any ideas? Thanks in advance
IG: project540ix
