09-10-2020, 11:16 AM | #1 |
Rep 21
2014 328i starting issue
For the past several weeks from time to time I've had a weird issue starting the car.
(115k miles 2nd owner @30k miles) (auto) The car acts like it is struggling to turn over and quickly stops trying. Up until a day ago. It only happened about once every ten starts. And when it did I would wait a second and try again and it would fire right back up like normal. Yesterday I had 2 consecutive sluggish start fails before getting it going and driving to work (~58 miles). After work one fail & fired right up. Once started there are no issues. Today I thought for sure I was stranded when I stopped for fuel. It took about ten tries to get it to run. But when I left in the morning no issue. I'm at work now and dreading getting off and being stuck. I ordered the starter and it's ready to be picked up but it's a hell of a task to change... was wondering if any of you gurus here could give any incite / opinions on what you think the problem is. I would've been certain it was the battery considering the sluggish attempts when it does fail but everything I know about a failed battery would say it wouldn't get better with more start attempts. However I would much rather take on the task of changing the battery instead of the starter! Thanks in advance guys |
09-10-2020, 03:09 PM | #3 |
2466
Rep 5,457
Drives: F30
If a major component failed (like the starter)... you would more than likely have codes stored. I don't believe it's a good idea to expensive throw parts at a BMW without pulling codes first. You might get lucky but then again, you might not.
killit9.00 |
09-10-2020, 03:24 PM | #4 | |
Rep 21
sspade2466.00 |
09-10-2020, 09:02 PM | #5 |
17
Rep 72
It still could be a battery issue. If the battery is installed new and properly coded, then they are good for 4 to 5 years more or less. If the battery is either not new or not coded properly to the car, you start to get electrical issues as the battery gets older. You can search the forums to read more about it. Not sure where you are but in the US, most auto parts stores can run a basic check of the battery and the alternator. Not sure of the starter can be done.
killit9.00 |
09-12-2020, 04:02 AM | #7 | ||
Rep 21
Thank you guys so much for your input! Now I've got to figure out how to code / get this thing coded! |
09-12-2020, 07:20 AM | #8 | |||
17
Rep 72
killit9.00 |
09-12-2020, 09:17 AM | #9 |
2466
Rep 5,457
Drives: F30
Glad to hear you got things sorted.
So in summary... you purchased a starter online because you didn't feel like pulling codes or getting your battery checked?! |
09-14-2020, 04:15 PM | #11 | |
Rep 21
09-14-2020, 04:31 PM | #12 | ||
17
Rep 72
killit9.00 |
09-14-2020, 04:32 PM | #13 | ||||||
Rep 21
09-15-2020, 04:18 PM | #16 | |
17
Rep 72
Replacement battery is same specifications as original, but is new. Requires update to charging profile. Replacement battery is different in specifications than original, Requires modification of charging profile. In both cases, do we just refer to the process as registration of the new battery? |
killit9.00 |
09-15-2020, 04:23 PM | #17 |
8245
Rep 16,088
If a replacement battery isn't the same as or very close to the original amp hour rating then you have to code to the nearest amp hour rating possible. In either case the battery must be registered, which is a different process from coding. Bimmercode, for instance, will do the former but not the latter. My Foxwell NT510 will do the latter, but not the former.
killit9.00 |
09-15-2020, 04:56 PM | #18 |
2025
Rep 2,806
Drives: F33 430 and F39 M35i
Sorry. I meant register
09-15-2020, 05:11 PM | #19 | |
17
Rep 72
killit9.00 |
