Has anyone here ever had a 2DED code..
09-07-2020, 09:23 PM | #1 |
68
Rep 81
I keep getting a pretty violent limp mode once the car warms up. I've seen it on the N54 forums, but I know that we have different DME's. Happens at random throttle positions, big yellow check engine light with the cross through it, no throttle response at all, Have to cycle the ignition for throttle control again.
Currently running a StageFp tune. |
09-08-2020, 07:02 AM | #2 |
Just one more taste...
566
Rep 2,011
Without scanning the DME with INPA/ISTA to get the codes that triggered it, we’d just be guessing.
What other electronics have you fiddled with? Any retrofits? https://www.justanswer.com/bmw/bw8zo...t-control.html |
09-08-2020, 08:21 AM | #3 | |
31
Rep 131
Are you sure it's that which is causing your check engine light? I'm sure ISTA P always reports it won't cause a check engine light. |
09-08-2020, 10:47 PM | #4 |
@Lucky.330i
39
Rep 91
Drives: 2006 BMW 330i
Got any aftermarket electronics hooked up to your car? Also when was the last time you replaced the battery?
09-23-2020, 11:58 AM | #5 |
The Girl With The Skills!
Rep 11
Drives: E92 N53 - 330i msport
Hi, new to site and been browsing threads, setting up profile and stuff saw this, having the same issue - Have 2008 e92 330i msport - Been having the usual age related issues recently, ive replaced the starter, main relay, oil exchange, rocker cover, coil packs & Sparks, Water Pump and Thermostat and brand new battery less that 4 weeks ago
... then after all this she had the 'Black Out' that ended up with her being recalled to BMW for the Positive Power line fix, this was exactly a week ago... since then ive had code 2DED, she wont start, battery is being drained and cant even use the boost pack to get her going... any ideas please? Im sound with the mechanics and programming but if its electrical i'm proper lost... any advice would be massively appreciated as this girl is my labour of love, we've been to hell n back together and i dont wanna quit on her now Cheers, Victoria
@[M80DCX](contact:522002)
TINK - BMW E92 330i m sport N53 - Bwaaaarp! |
09-23-2020, 02:19 PM | #6 | |
278
Rep 657
09-23-2020, 02:35 PM | #7 | |
Rep 11
Tried a battery reset, erased the code and still nothing though...
09-23-2020, 03:56 PM | #8 |
31
Rep 131
Open your bonnet/hood and check the sensor on the cowling is getting pushed down properly when it's shut. That's what triggers the code for me, probably not what your problem is but worth checking.
Also unplug as many things as possible that aren't necessary (amp, mulf, anything aftermarket) to try and narrow down what is drawing power. Maybe try shutting the car off, get a multimeter and then check the fuses for any current. Or you should be able to infer which ones these are from the schematic/wiring diagrams. Also I would start your own thread in the electronics forum because you'll hopefully get someone with a lot more knowledge of the car electronics. Edit: the fact that it won't start sounds like it might be the IBS sensor based on what others have said. You'd save yourself a lot of effort checking the codes with INPA/ISTA or finding someone who will do it for you. Cables are only cheap and the software is easy to install. Last edited by 4foothill; 09-23-2020 at 04:05 PM.. |
