09-02-2020, 06:46 AM | #1 |
1616
Rep 2,274
Lowering Springs - 540i xDrive
Hi All,
I know there are many threads relating to lowering springs but thought i'd start my own Looking to drop the ride height and get rid of the gap between the wheels and arches. On my F30 335d xDrive, I went for AC Schnitzer springs which were great. More recently on my F06 640d I went for Eibach's but the drop wasn't that great at the front. For those that have lowered, qhat have you gone for? The car is non VDC. I will be fitting 15mm spacers all round soon. Found a thread on here where it was lowered on ACS but the owner wasnt it too happy with the results. https://g30.bimmerpost.com/forums/sh....php?t=1579468
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
09-02-2020, 10:51 AM | #3 |
1616
Rep 2,274
Thank you.
I'll look into that. Hopefully someone comes along on here who's done it and has some pics to show
IG: project540ix
09-02-2020, 01:12 PM | #4 |
49
Rep 56
Drives: 2018 540i M sport, Eurocharged
Hey I'm lowered on H&R sport springs, approx drop is 1.4" all around. Ride is absolutely horrible now, not that it was any better when stock, I prefer the aesthetics.
Junebug851616.00 |
09-02-2020, 02:17 PM | #5 | |
1616
Rep 2,274
The stance looks really good. Are you running Spacers too? I want to do it more for the look!
IG: project540ix
09-03-2020, 03:36 AM | #7 | |
1616
Rep 2,274
I'm yet to experience worse ride quality and handling on a lowered car. From my experience, My F30 335d xdrive was lowered in ACS springs. This improved the look, handling and made the car feel more planted. More recently, my F06 640d was lowered on Eibach springs. Again the look and handling were improved in my opinion. It gets rid of the body roll and nose diving. A combination of shocks and springs will definitely improve handling but from what i've found, a spring change does enough for me. Interesting regarding the comment that the G30 was worse when lowered... normally its the other way round.
IG: project540ix
09-03-2020, 07:03 AM | #8 |
283
Rep 292
Have ever lowered with proper coil-overs before? The factory shocks are not meant to support lowered springs. BMW has tuned the struts to specific spring heights for ride and performance.
Sorry to tell you but if you think your handling and performance isn't compromise that is incorrect. I'm not trying to be rude here but trying to let you and others who are thinking about doing the same that handling and ride will be compromised period. Please do an online search of lowering springs without replacing factory shocks. |
09-03-2020, 07:34 AM | #9 | |
1616
Rep 2,274
IG: project540ix
09-03-2020, 07:51 AM | #10 |
283
Rep 292
https://www.mycarforum.com/forums/to...shocksdampers/
Here is a pretty good write up. |
Junebug851616.00 |
09-07-2020, 04:40 PM | #11 | ||
49
Rep 56
09-07-2020, 04:43 PM | #12 |
49
Rep 56
I did it for primarily looks as I don't drive that far and this car already doesn't have good suspension in my opinion. Also definitely not spending 3k on coilovers on a car that's not meant to be thrown around a corner.
09-07-2020, 08:57 PM | #13 |
281
Rep 387
If you wanna be lowered in your 5-series, I think the only way to do it without really turning your suspension into garbage is to go coilovers. With a coilover you get a stut and spring already engineered to work together.
Be prepared to spend $2500 or just don't lower your 5. The best coilovers found here. https://www.kwsuspensions.com
2020 540i MSport | Alpine White | Mocha Nappa | Aluminum Rhombicle | Exec Pkg | Luxury Seating | Bowers & Wilkins | Parking Assistance Pkg | MSport Brakes | Ceramic Controls | Space Saver Spare |
09-08-2020, 12:14 AM | #14 | |
283
Rep 292
10-03-2020, 01:31 PM | #15 |
1616
Rep 2,274
This is an interesting read...
https://g30.bimmerpost.com/forums/sh....php?t=1686086 Hearing good things about MSS.
IG: project540ix
10-06-2020, 04:41 AM | #16 |
1616
Rep 2,274
Going to go for this...
I like how you can adjust the spring height and set it to how you want it. Been speaking to Evolve Automotive and planning to get this done soon. A bit more cost wise then the Eibach Pro but definetly worth the money from what I've read and seen on YouTube. Even Joe Achilles has them on his M2 Comp!
IG: project540ix
11-30-2020, 11:24 AM | #17 |
1616
Rep 2,274
IG: project540ix
10-23-2022, 09:40 AM | #18 |
Rep 7
I was thinking about going the larger tires route also like putting seven series that has 20 inch rim but the same tire profile as the 19 inch but that increases the rolling diameter to an inch more and I hear the BMWs are very finicky with regards to gearing and can mess things up
10-23-2022, 09:44 AM | #19 | |
Rep 7
