BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > RSA Delete - WinFPK Crashed - Car Cranks No Start
      08-27-2020, 08:39 AM   #1
javeci01
Drives: 2007 328i
Hi everyone.
I was trying to flash RSA Delete to my 2007 328i. I checked before flashing that INPA worked, and I was able to read codes and check live readings.
When I started flashing RSA Delete, it appeared everything was working, but then WinFPK crashed and exited. I then received the following message in the DOS.
[C:\EC-APPS\NFS\BIN\MSV80.ctl] [19.08.2020, 21:47:31]
[MULTIFLASH]
MF_FG_NUMMER=
MF_PABD=12msv80.ipo
MF_PSGBD=12MSV80.prg
MF_SG_ADR=12
MF_NAAB_DATEI=
MF_PROGRAMM_DATEI=MSV80_RSADelete_0049QK0MI20S.0pa
MF_DATEN_DATEI=
MF_DIAGNOSEPROTOKOLL=
HW interface activted.
PABD set.
P-SGBD set.
INFO000=Error: Error 106: Error on setting ECU-Adress. Please check: Interface, PABD, P-SGBD
INFO001=Error: Error 2000: Error LFCDHDIA.CPP (12msv80.IPS/IPO) CDHapiResultText 1 Error in EDIABAS or in ECU description file (SGBD) SYS-0010: Initialization error 12MSV80
INFO002=Error: Error 2000: Error COAPI2.CPP coapiRunCabd 6 Error in EDIABAS or in ECU description file (SGBD) SET_ECU_ADDRESS
INFO003=Error: Error 2000: Error COAPIKF.CPPcoapiKfSetGlobalPabdSgbdEcuAddr 5 Error in EDIABAS or in ECU description file (SGBD) Run SET_ECU_ADDRESS Job
Error: ECU-Address could not be set!
ERG=Programming not ok. Fatal Error
Batch mode ended
Press any key to continue . . .
Now my car cranks, but won't start.
Any help would be appreciated. I really hope I didn't brick my DME.
I checked and I still have access to INPA and can read codes for whatever that is worth.
Apologies to E92William for hijacking his thread yesterday while in a state of despair/terror.
Thanks!
      08-27-2020, 07:51 PM   #2
fastboatster
382
Drives: 2009 bmw 328i
Mb try to flash stock sw back? Or try to repeat the RSA flash again. Are you running in VM? Not msv related but I tried to flash some other tricore ecu 2 days ago from Windows VM on my mac and the flash failed 2 times in a row. Granted, it was some aftermarket flasher so probably not as good as winkfp but you get the idea.
      08-27-2020, 08:01 PM   #3
nsjames
2440
Drives: 08 328xi Touring
i've gotten him through importeing the required files into winkfp
we're now here:
Code:
[MULTIFLASH]
MF_FG_NUMMER=
MF_PABD=12msv80.ipo
MF_SG_ADR=12
MF_NAAB_DATEI=
MF_DATEN_DATEI=
PABD set.
P-SGBD set.
ECU-Address set.
Data and/or program and/or NAAB file set.
Program will be programmed.
INFO000=Error: Error 211: Error on flash programming!
INFO001=Error: Error 2089: PABD 05MSV80 Programmieren 2544 switching programming mode failed 12MSV80, DIAGNOSE_MODE (ECUPM): ERROR_ECU_SECURITY_ACCESS_DENIED__SECURITY_ACCESS_ REQUESTED
INFO002=Error: Error 2084: PABD 05MSV80 FlashSchreiben 1448 Flash download failed 12MSV80, FLASH_SCHREIBEN (...): ERROR_ECU_INCORRECT_BYTE_COUNT_DURING_BLOCK_TRANSF ER
INFO003=Error: Error 2084: PABD 05MSV80 Programmieren 3247 Flash download failed 12MSV80, FLASH_SCHREIBEN (...)
INFO004=Error: Error 2084: Error COAPI2.CPP coapiRunCabd 6 Flash download failed SG_PROGRAMMIEREN
INFO005=Error: Error 2084: Error COAPIKF.CPP coapiKfProgSgDevelop 4 Flash download failed
Batch mode ended
      08-27-2020, 08:11 PM   #4
javeci01
Drives: 2007 328i
Thanks, I am trying to flash the RSA delete again. Its going very slow 10% in 20 minutes.
      08-27-2020, 09:03 PM   #5
javeci01
Drives: 2007 328i
It worked! Thanks everyone who helped out! What an amazing group of people on here.
      08-27-2020, 09:23 PM   #6
bluewater328
626
Drives: 2011 bluewater 328i LCI sedan
So what was the underlying issue. Just old DATEN?
      08-27-2020, 09:24 PM   #7
Mantraxalos
78
Drives: 2006 330i Manual
2007 Z4 3.0i  [0.00]
2006 330I  [0.00]
Great, now I'm going to be asking you for advice when I finally get to the Zed!
      08-27-2020, 09:52 PM   #8
javeci01
Drives: 2007 328i
Yes, it worked after downloading the e89 daten and importing.
nsjames shared the below PDF which was very helpful. EXCEPT DO NOT do the last part of the PDF, the WinFPK configuration (use the Bimmerlabs WinFPK configuration, at least that's what I did).
https://www.e90post.com/forums/attac...=1432591135#:~
      08-27-2020, 09:54 PM   #9
Mantraxalos
78
2007 Z4 3.0i  [0.00]
2006 330I  [0.00]
Nice, I'll try to get mine done on Sunday.
      08-27-2020, 10:23 PM   #10
E92William
1998
Drives: 2008 E92 328xi
2008 BMW 328xi  [0.00]
Glad you got it sorted. No big deal about hijacking the other thread. It's kind of there half for troubleshooting and half for new things lol
      10-03-2023, 05:23 AM   #11
Alexvier
Alexvier's Avatar
35
Drives: Crimson Red 325i M sport
Yes I’m getting a no crank start now too from doing the RSA delete. There was a few errors and after trying the 0da files there’s no response now.
I tried the RSA delete a couple of times but now there’s just no communication with the car.
Does the RSA unlock the DME with just the altering the power class?
How can you undo the RSA delete?
Ultimate Driving Experience........
      10-03-2023, 09:17 AM   #12
cosmosschwarz
Drives: E91 325xi
If the RSA delete fails, you need to reload the stock tune saved on the bimmerlabs page, then try the RSA delete again.
