08-17-2020, 06:56 PM | #1 |
10933
Rep 4,551
Drives: 2015 328d xDrive
Hey all,
Poochie recently directed me to a thread on the 2 series forum that discusses various HK Amp EQ settings: https://www.2addicts.com/forums/show....php?t=1723637 Long story short: Bimmercode -> Amplifier -> Expert Mode -> EQ After playing around with it and doing some reading the F45 setting seems to be the clear winner. I went with that and changed the tone settings to: Bass +2 Treble +3 and Fader +1 Rear. What a huge improvement! I was thinking about eventually going with aftermarket speakers & an amp due to the lackluster sound, but after this discovery I'm now perfectly content with the stock system and will be leaving it as is. And the best part is that if you already have bimmercode, it's free! Edit: I've since switched to F22 new and set the iDrive EQ to +5 Bass/Treble Last edited by AndrewC1989; 09-08-2020 at 08:43 AM.. |
Poochie9104.50 Altra267.00 F87source7291.50 Black Flagged471.50 PLF693768.50 mzcp2692.00 Got f1?682.50 NYC Bimmer259.50 Badmon33.50 puffdaddy8.50 |
08-17-2020, 08:58 PM | #2 |
Luxury at the redline :)
9105
Rep 7,563
Another great write up
I hear a tremendous amount more bass now, when blasting my gangster rap music I love this adjustment, just wish I had discovered it sooner.. I have a theory that BMW didn't originally adjust the bass and heights, like they did in the F45 setting, to avoid blowing out the subs and tweeters - but whatever, they sound perfect now |
AndrewC198910932.50 Got f1?682.50 |
08-18-2020, 01:20 AM | #3 |
1917
Rep 2,136
As I wrote in that original thread, the F45 settings are way too overboosted in the bass, making it unbearable for anyone with an aftermarket sub.
For a completely stock system, I can see the appeal. But do not use it after adding any aftermarket sub/amp. It’ll muddy the whole sound. |
08-18-2020, 01:30 AM | #4 | |
7292
Rep 7,460
1) HK Amp: https://www.realoem.com/bmw/enUS/sho...diagId=65_2671 All of them except 1 p/n was also used in the m2, but since they are all interchangeable they should all be able to supply the same power ratings so this coding shouldn't mess with the amp too much. 2) HK tweeter: https://www.realoem.com/bmw/enUS/par...&q=65139226357 Same as the one in the m2, m3, m4 so we should be ok here as well 3) mid rang door speaker with HK pack: https://www.realoem.com/bmw/enUS/par...&q=65139364956 Same as in the m2, m3, m4 so we should be ok on the front too 4) The rear door speaker: https://www.realoem.com/bmw/enUS/par...&q=65139364956 It shows as present on the m2, m3, m4 because the p/n is the same as the mid range door speaker. I acannot remember if the rear of the m2 has this speaker in the side panel but it is the same if present. 5) Rear door tweeter: https://www.realoem.com/bmw/enUS/par...&q=65139226357 Same for the m2, m3, m4 if we have rear door tweeters in the m2 wherever it would be relocated. 6) a) Left sub:https://www.realoem.com/bmw/enUS/par...&q=65139256349 b) right sub: https://www.realoem.com/bmw/enUS/par...&q=65139256350 Not the same as the m2, and not reallt shared on any 2 series outside of the f45 and f46. We may see a problem here, I am not sure if it is different because of the size and shape or if it is a component with different power specs too. If it is the later we may have a problem if bass is cranked too high. 7) Center speaker: https://www.realoem.com/bmw/enUS/par...&q=65139368383 Same on the m2, m3, m4 so no issues here So yeah overall I think the only factor we have to worry about is the subs, so just be gentle if you code this with how much extra bass you add in the idrive.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
08-18-2020, 11:35 AM | #5 |
3769
Rep 2,700
Holy smokes, I just did this, huge improvement !!!
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
AndrewC198910932.50 |
08-18-2020, 12:42 PM | #6 | |
10933
Rep 4,551
I don't DD my car and won't be setting the bass super high so I'm not too concerned with sub longevity, but if they do ever blow out I'll be probably be throwing in some bavsound/bimmertech woofers. |
NYC Bimmer259.50 |
08-18-2020, 01:59 PM | #7 |
561
Rep 212
Drives: BMW F87 M2C
Did mine this evening, definitely seems to have more noticeable bass
08-18-2020, 02:32 PM | #8 | |
36
Rep 38
08-19-2020, 09:14 AM | #9 |
10933
Rep 4,551
Just to be clear, the tone settings and the EQ coding are two different things. Running both in tandem is what makes the sound change so significant.
NYC Bimmer259.50 |
08-19-2020, 09:23 AM | #10 |
10933
Rep 4,551
Not sure if this is because I was parked with the engine off when I was testing but It feels like I don't have to have my volume turned up as high anymore to get the same noise levels I like. Before there was a huge dead zone and I'd have to have my volume above 80% just to hear anything and now it feels like i can actually have it set to 50%. I'll have to go for a drive to confirm but it seems like another added benefit.
NYC Bimmer259.50 |
08-19-2020, 09:51 AM | #11 | |
9105
Rep 7,563
How I know this is because I have dash cam that records audio also, so was playing back a recording last night and I can hear the difference in heighten sound, from my prior recordings - which I wasn't even looking for but it was interesting to discover. If you have something that records decent audio, you can try it, to and fro, to decipher the difference. Not sure what voodoo magic the new EQ setting is creating but the stock HK system does sound much better now. When I get a chance, I want to also try out the other model's EQ coding and see if they sound subjectively better. Not that it's necessary but you know, why not |
08-19-2020, 02:40 PM | #14 |
1917
Rep 2,136
08-19-2020, 04:23 PM | #15 |
7292
Rep 7,460
I'm going to give this a try at some point, but with the bass dialed way back because I am not a bass guy.
08-19-2020, 06:06 PM | #16 |
758
Rep 1,337
Where is the coding stored? In the amp or the head unit ie: if you have replaced the amp does this setting have any affect?
Previous Rides: 13' 135i, 08' 130i, 03' HKS Turbo'd 350z, Modded GC8 WRX, NA MX5
08-19-2020, 06:12 PM | #17 | |
7292
Rep 7,460
It won't work if you do not have a Karmon kardon amp from bmw because you are accessing the amp itself. If you have an aftermarket amp it will not work or won't do anything.
AndrewC198910932.50 MR RIZK757.50 |
08-19-2020, 08:10 PM | #18 |
194
Rep 309
Drives: 2018 M2 LBB - 6MT
Thanks for posting this. I'm thinking of doing this soon, should I leave my center speakers disconnected? I think the answer is yes, just curious what others are doing.
08-19-2020, 08:12 PM | #19 |
10933
Rep 4,551
You can leave it disconnected if you want, it's personal preference. I left mine connected.
gphung193.50 NYC Bimmer259.50 |
08-20-2020, 08:49 AM | #20 |
1163
Rep 1,413
Is this for M2C or M2? Will check it out on my C this evening.
08-20-2020, 09:24 AM | #21 |
Car Designer
292
Rep 263
mine is a 2019 M2C With Harman Kardon and it works
You guys know if there is any chance to have Spotify as Idrive app? I felt that using spotify trough the smartphone with this new settings the audio quality drops massively compared to DAB radio station |
08-20-2020, 09:42 AM | #22 | |
1163
Rep 1,413
