08-17-2020, 07:43 AM | #1 |
Rep 23
OEM Engine Coolant Mix With Tap Water Or Distilled Water?
Need to top up my engine coolant on my 428i and I got some OEM concentrate that needs to be mixed. The technician at the dealership said they use regular tap water when they replace it/top it up on cars. Should I use distilled water or normal tap water to mix it? I'm not sure if I can get hold of distilled water unless I order online *
08-17-2020, 09:55 AM | #3 |
8246
Rep 16,091
Depending on the mineral content of your tap water using it can cause everything from mineral deposits on the heater and radiator coils to system corrosion. Distilled water is cheap insurance against that. I get mine at my local grocery.
08-17-2020, 09:56 AM | #4 |
Rep 23
I went and got some de-ionised water, same thing as distilled pretty much
08-17-2020, 10:14 AM | #5 |
8246
Rep 16,091
De-ionized is OK, as it has metal and mineral content removed via filtering. Distilled is higher in purity, but it's more expensive, and the purity of de-ionized is adequate.
