Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Another turbocharged n52..
      08-16-2020, 06:15 PM   #1
Kiddvegas
Kiddvegas's Avatar
68
Drives: F87 OG
Long time lurker, first time posting on here.
After months of research, I’ve managed to boost my e92 328i. I’ve owned the car for almost two years, and it’s my first bmw. I originally purchased the vehicle with 90,000 Kms, completely stock. It’s pretty tough to find a 328i or 335i in Vancouver that’s a manual transmission, and not a totally sacked out unit.
My previous vehicle was a 2013 Audi S6, with hybrid turbos/ supporting mods, so I’m not totally unfamiliar with aftermarket forced induction setups.
Mods are as followed,
- Holset He351cw turbo
- Stock collectors into T3 flange turbofold
- Bosch EV1 590cc injectors
- Tial mvs external wastegate
- Turbosmart Raceport BOV
- MAF delete
- Stage Fp software/ remote tune
- 135i 5” aftermarket intercooler
- Custom catch can
The suspensions and brakes were changed almost right away, Coilovers, swaybars, and brembo GT6’s on the front.
I’m currently just running a 3” down pipe until I decide what I’m going to do for an exhaust. (It’s loud AF, but does sound pretty tight) Believe it or not, the stock clutch is holding quite well with only the delay valve deleted. The wastegate spring pressure is at 9 pounds, makes full boost by 3000 rpms.
Cost wise, this was still cheaper then the Ess blower kit, plus it has wayyyy more potential. If anyone needs tips or has any questions I’m glad to help. I have videos of the car on my insta. Kiddvegass
Appreciate 11
alfazrus101.00
E92William1998.00
gT-BMW203.00
dwashy64.50
Silnismo225.50
Saico29.50
AmuroRay2282.50
Ali-E90378.50
uber114.00
whyzee1251678.50
      08-16-2020, 06:43 PM   #2
houbmw
66
Drives: 2007 530i Sport with SMG
Props to you man! Glad to see progress on this platform.
Now for the 500 comments on "just buy an n54" lol
Appreciate 2
      08-16-2020, 07:04 PM   #3
Kiddvegas
Kiddvegas's Avatar
68
Drives: F87 OG
Haha, by the hundreds I’m sure. Lucky to find a 335 out here with less then 200000kms.
      08-16-2020, 08:33 PM   #4
W37V
[Oo=||=oO]
No_Country
1103
Drives: e92n52 & f15n57
Congrats man. This is impressive build. Did you manage to keep your AC? What did you do with the coolant expansion bottle?
Your IG profile is private, so your videos and other related posts are not accessible to people who don't have IG (like myself).
Who build the manifold?
      08-16-2020, 09:51 PM   #5
rick100
551
Drives: 328
same question , do yo still have ac? any dyno numbers? im assuming you still have n52 transmission
      08-16-2020, 11:12 PM   #6
Kiddvegas
Kiddvegas's Avatar
68
Drives: F87 OG
Yes I managed to keep the AC. As long as it’s a top mount manifold, you can clear the AC pump no problem.
Expansion tank was rerouted to the other side, by the power steering reservoir.
I had a good friend who’s a fabricator build the manifold.
N52 transmission still as well.
Appreciate 2
Noir883.00
Ali-E90378.50
      08-17-2020, 04:02 AM   #7
E92William
1998
Drives: 2008 E92 328xi
2008 BMW 328xi  [0.00]
This is pretty bad ass. Are you utilizing the valvetronic or is it locked at full lift and using the throttle plate?
Biginboca3763.50
      08-17-2020, 12:58 PM   #8
Noir
Noir's Avatar
883
Drives: 2006 E90 330i 6MT
nice
Given the amount of boost you're hitting, not running Into cooling issues yet???
See you, space cowboy.
Supercharged
      08-17-2020, 02:04 PM   #9
houbmw
66
Glad to see the n52 transmission holding up!
Would the intercooler not help the cooling issues?
      08-18-2020, 08:32 AM   #10
scanspeak
scanspeak's Avatar
Australia
354
Drives: BMW E92 325i 12/2007
Impressive work. Need to see a dyno chart!
      08-18-2020, 09:38 PM   #11
HydroxFrost
@Lucky.330i
HydroxFrost's Avatar
39
Drives: 2006 BMW 330i
This is pretty sick, I'm planning on doing this at some point next year when I finish my turbo jeep "SRT-4". Nice fab work on the manifold as well.
      08-19-2020, 08:44 AM   #12
dwashy
65
I'm inspired! I've got headers on now and the old factory ones are sitting in the garage. I need to break out the welder and try to get a manifold created, glad to see it's possible 😁
N52 | +1mm MILVs | Catless | 3-Stage IM | BPC Tune | 3.64 diff | AirLift Performance 3H | M3 Control Arms | SPL Parts BumpSteer Correction | UUC Evo 3 Shifter | CCV Delete | Valeo SMF Flywheel | CSF Aluminum Rad | VAC Front Hub Extenders | BMS Cowl Filter Delete
      08-19-2020, 09:35 AM   #13
Silnismo
226
Drives: BMW 325i
This is sick, tell your friend to produce more of those manifolds and I'm sure he can make some decent pocket money.
Also love to see the dyno results as well
      08-21-2020, 03:40 AM   #14
AlexKoast
AlexKoast's Avatar
92
Drives: e92 TiAg 335i 6MT
Noticed you're in Vancouver, do you have come out to any of the end of month meets or Thursday meets? Curious to learn a bit more. Also on the BC Bimmers facebook page.
Current: e92 335i 6MT FBO + e90 330i 6MT | Former: e46 330ci 5MT | IG: @Axel.Koast
      08-21-2020, 02:10 PM   #15
fastboatster
382
Drives: 2009 bmw 328i
OP, just buy an n54. Jk, great work! Do you have some kind of external boost controller to control the boost?
      08-31-2020, 02:44 AM   #16
200,000 club
28
Drives: BMW e90 328i 6MT
Cant wait to see dyno numbers. Also, since n52s use the same rod bearings as the n54, would they need to be changed if you go turbo?
      09-06-2020, 04:55 AM   #17
E90SRB
Drives: E90 328i X-Drive
I respect the build, looks super clean. Where in Vancouver are you located? I'd love to see this.
      09-07-2020, 09:15 PM   #18
Kiddvegas
Kiddvegas's Avatar
68
Drives: F87 OG
Originally Posted by Noir View Post
nice
I wondered about this myself, Especially after reading some of your comments in regards to your blower setup. I'm under the impression that with a Decent sized air to air, all should be good? I'm going to swap a N54 oil thermostat/ oil filter housing at some point this fall or winter, since temperatures are going down for the season. I would assume that if the oil isn't getting to hot, everything should be fine? I hope..
      09-08-2020, 02:20 AM   #19
Noir
Noir's Avatar
883
Blank
Well, I am in hot ass Texas... YMMV.
I am in the same boat with the oil cooler thang...
If you can find the old BPC thread (idk if it's deleted or not) they were running the oem N54 intercooler : you probably could get by just fine in the initial stages with that if you're not going crazy with the boost juice.
Supercharged
      09-08-2020, 09:19 AM   #20
Kiddvegas
Kiddvegas's Avatar
68
Drives: F87 OG
I read one time in school that it get a lil’ toasty down there, haha.
The the N54 intercooler I installed was one of those eBay brand ones, it’s like a 5x5” Core. Didn’t fit the best, and I had to basically cut the shit out of the inlet outlet, but it works. I’ll be trying to monitor my AIT’s. Are you going to retro fit a stock N54 one ?
      09-08-2020, 11:02 AM   #21
Hobbs64
38
Drives: 2007 328xi
Preops on a great (and creative) build. I have a million questions as I'm just putting together a bottom mount GTX3582R build. Are you running your build off a stock ecu? As was already asked, did you keep valvetronic? I'm tempted to do away with mine.
Any help you can give me with tuning would be greatly appreciated!
      09-08-2020, 01:12 PM   #22
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
I'm not a turbo specialist by any definition but that think looks HUGE. How long does it take to spool up? The N52 probably need 900kg /hour of air to make 300hp give or take , maybe 6 lbs boost. Just guessing and the turbo is rated for far more air and pressure. 1000KG/ @ 7 psi being the bottom of the chart.
The two tiny turbos on my N54 are holding 13 PSI at 1050 KG/\hour. And I wish they spoiled up quicker.
