Switching DRL (H7's) w/ a H.I.D. system.
09-30-2008, 01:22 PM | #1 |
205
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
I have been interested in switching my Day Time Running Lights in my 2008 335xi w/ H.I.D. lighting package. i was looking to swap the factory H7 bulb w/ a whiter bulb w/out incurring the expense of a HID system for the day time running light. this is what i found out f/ my local BMW dealer in Bel Air, MD.
they advised they would need to pull the front bumper cover and remove the light assemble out far enough to swap the H7 bulbs. if this was warranty work they would get 1.6 hrs of labor to make the switch. i went for it if they let me watch so if i need to replace a blown bulb later on. well after it was all said and done, you can't tell a big difference when it is used as the lower voltage DRL, but when you flash the lights it is the much whiter light you see on cars that have those blue bulbs, that looker whiter. i also switched the fog lights on my own, w/ a whiter light and got great results. much easier to do. just remove the bottom panel under the fogs and make the switch. took 10 min. tops. i did by buy a light switch that lets you turn on the rear fog lights. (Tischer BMW) in Wash. DC area, they are a forum sponsor. this is the same switch used in Europe. it's great, just a plug and play item. no codes to program in the computer. and no error codes either. you only loose the adaptive brakes light on the car. these only come on at best a second when braking hard. i'd rather have the rear fog lights like my wifes Volvo, and the Audi i used to have. so if you are looking for a cheap way to replace your DRL's, you would have to do the work yourself. other wise save your $$$. http://www.e90post.com/forums/images...es/roundel.gif good luck! Last edited by Spydeputy; 05-10-2009 at 12:35 PM.. |
09-30-2008, 01:47 PM | #2 | |
Russian in a Bimmer
568
Rep 5,619
2013 X6 - retired
2015 X6 - retired 2015 435GC - retired 2018 X5 40e - retired 2020 X5 M50i - Current |
09-30-2008, 03:48 PM | #4 | |
35
Rep 712
Drives: 2007.5 E90 335xi Montego/Lemon
I wish it was as easy as on the halogens, where it's a simple snap and twist motion to remove and replace the bulb. I would've changed my bulbs a long time ago....
09-30-2008, 04:36 PM | #5 |
205
Rep 3,523
they truly are Xenon H.I.D. lighting. yes i can see the 3 clips to take off the cover, i know that both type of lighting are behind the same cover but not enough room to take it off as it sits w/out removing the wheel and wheel well cover, or as the dealer show me in their manual, remove the bumper cover, and then the few screws that hold the light assembly.
either way... it ain't easy. |
