BMW 2 Series Gran Coupe Forum (F44) BMW 2 Series Gran Coupe (F44) General Discussion
      08-06-2020, 11:46 AM   #1
Kothar
175
Drives: 20 m235i gran coupe
Its early but let's talk winter tires
well the search is on now for a set. And to my surprise the bolt pattern is not
5x120 as most bmw have but 5x112. So my previous set from my m2 will not fit. I'm going with a r163a replika 18 inch wheel and michelin pilot pa4 winters 225 40 18. I ran same tire on m2 and it did good in winter but was on rwd car. On this xdrive should get even better traction.
      08-06-2020, 08:01 PM   #2
CyberYYZ
26
Drives: BMW M235i
Kothar agreed as a fellow Canadian I too have started to think about snows and rims. Do you have a picture of the rims you are considering that you can share and prices for those rims and tires?
      08-06-2020, 08:19 PM   #3
Kothar
175
Here they are on my old m2 18 inch. I got quote for this 4 wheels 5x112 bolt pattern mounted balanced and pa4 for $1799 tx inc from local shop here in London.
      08-06-2020, 10:38 PM   #4
CyberYYZ
26
Drives: BMW M235i
Please share the contact info for your London tire shop. I may give them a call and drive to London if the price is right
Thank you
      08-07-2020, 02:40 PM   #5
Sportstick
Sportstick's Avatar
4654
Drives: '15 228i and '24 X3 sDrive30i
Traction is a function of the tire, not the vehicle, not the drivetrain. With xDrive, more tires can be under power and generate their inherent level of traction, but at four contact patches instead of two. The traction capability of each tire remains the same; it does not get better. The enhanced forward motion is a result of more tires with their existing level of traction being under power to move the constant weight of the vehicle. The tire's traction does not increase, and the car riding on top of the tires has no traction with the ground.
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCAs/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerformance Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/Adam's Ceramic/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner
      08-07-2020, 05:44 PM   #6
Kothar
175
Thank you
PM'd you.
      08-07-2020, 05:48 PM   #7
Kothar
175
Well essentially that is what I meant. there will be 4 patches with power going down with weight of car vs 2 in the previous rwd setup. The stopping of the car will be no different with the same tire as stopping on ice/snow a function of the tread and specific tyre....albeit with the abs and other related nannies.
But I will bet that this car will be better at getting around in snow than the m2 I had with the same tires.
      08-07-2020, 07:44 PM   #8
Sportstick
Sportstick's Avatar
4654
Yes, it should. And, even moreso if you stay within Michelin but go from PA4 Alpins to XIcexi3!
      09-16-2020, 12:58 PM   #9
LuCanBimmer
12
Drives: M235i GC
For the Canadian owners, the F44 M235i requires separate TPMS.
      09-16-2020, 07:59 PM   #10
Kothar
175
Yeah the system actually shows psi for each tire i assume if you put a set on without tpms the system onbaord will give warnings. How.much extra will tpms be?
      09-17-2020, 08:25 AM   #11
LuCanBimmer
12
Drives: M235i GC
Extra $200 cad
      10-04-2020, 10:27 AM   #12
CyberYYZ
26
Drives: BMW M235i
not sure TPMS is required
Hello everyone, I made a number of calls to tire shops in Toronto area and received mixed answers on whether TPMs are even necessary.
One shop that I have used numerous times to purchase tires said the sensors are not required as they are part of the suspension and owners will not need to purchase separate sensors.
this goes against what many of you have posted here. Hoping a BMW guru or genius can provide insights or even better share tech specs that answers this once and for all.
Thank you
      10-05-2020, 12:08 PM   #13
CyberYYZ
26
Drives: BMW M235i
TPMS sensors are crazy expensive from the dealer
Extra $200 cad
Just to confirm is that per TPMS sensor (which are part of the valve stem) according to BMW dealer?
the dealer quoted my $151 per sensor which sounds crazy!!!!
Please provide thoughts and recommendations on this one as soon as possible!
      10-05-2020, 06:53 PM   #14
Kothar
175
Just put my set on today tpms unfortunately are needed did not realize until recently but an extra $160 or so for all . A little higher in price than I thought but still ok.
      10-06-2020, 12:48 PM   #15
CyberYYZ
26
Drives: BMW M235i
Thanks Kothar
And they were part of the valve stem ?
Ps would love to see pictures of your winter setup as you are first out of the gate on winter tire install
      10-06-2020, 03:22 PM   #16
Kothar
175
Thanks Kothar
Pics coming wed. Yes part of valve stem inside tire. They cloned data from summer setup and no warnings in idrive good to go.
      10-07-2020, 08:41 AM   #17
Kothar
175
Winter tire/wheel setup black Ruffino Inception 18 inch with Michelin Pilot PA4's
      10-07-2020, 01:31 PM   #18
LuCanBimmer
12
Drives: M235i GC
I'm installing my winter setup in two weeks time. I thought the TPM would be a plug n play type scenario (i.e. Reset the TPM in idrive).
How would I go about cloning my summer setup to winters?
      10-07-2020, 05:12 PM   #19
Kothar
175
I'm installing my winter setup in two weeks time. I thought the TPM would be a plug n play type scenario (i.e. Reset the TMP in idrive).
My tire shop did it all...I was going to wait and take them home and likely out do in 2 weeks bolt on but since there i said just do it now. Pa4 still has great dry handling. If tpms on your own I am not sure how you could clone them. These guys did it all in 40 min no errors in idrive I'm good to go.
      10-08-2020, 07:51 AM   #20
LuCanBimmer
12
Drives: M235i GC
Appreciate the response, I will book an appointment with my local shop.
      10-09-2020, 08:21 AM   #21
BlownLSX
BlownLSX's Avatar
No_Country
213
Drives: C6Z, X3MC
Ordered a set of Moda split 5 spoke from tire rack with my dealer account. 460$ shipped to my door. Came with full hardware and centering rings. Sending them out to my friend to have sprayed metallic black gloss. Wheels will be wrapped in blizzaks.
      09-17-2021, 06:01 PM   #22
david52
Drives: bmw
Hey guys, late to the party lol but getting the m235i ready for winter. Ecstuning.com confirmed CyberYYZ that our car does not have direct pressure sensors, did anyone try without tpms?
