Non run flats staggered setup tire pressure
08-05-2020, 09:17 PM | #1 |
895
Rep 3,141
I used 36psi when I had stock 17 inch, sport package run flats OEM Bridgestone Potenza. I finally ditched run flats, and switched to non run flat Michelin Pilot Sport All Season 4. I’m not sure if should set the Michelin’s to 36psi, or 32psi. My bmw technician recommended 36psi, my Indy recommend 32psi. I’m leaning towards 36psi. Any suggestions? Thank you.
2008, E90 sport package. |
08-06-2020, 02:55 AM | #2 |
25
Rep 86
I have staggered 17" non-runflats. Continental ECS. 32psi fronts 35psi rear.
This allows for enough expansion when hot. How do you like the new Pilot AS4 tires? I've been very happy with the AS3+ on my other cars. |
08-06-2020, 08:13 AM | #3 |
895
Rep 3,141
I like them. The ride is much smoother, quieter, and comfortable. I was thinking of putting 36psi on all 4. Or just leave them at 32psi. My car sits for about 3, to 4 days. I had the low pressure light come on twice.
Do you carry a spare? |
08-06-2020, 04:57 PM | #6 |
895
Rep 3,141
I went with 36psi on all four tires today.
The temperature dropped about 10 degrees last night. And so did my tire pressure. It went from 32psi yesterday, to 28psi this morning. |
08-07-2020, 09:38 AM | #7 |
2442
Rep 4,330
https://static1.1.sqspcdn.com/static...+inflation.pdf
the load range is what matters here. compare new load range to old with the chart, it will get you in the neighborhood. but really the proper way is to chalk the tread and sidewalls and see how much the tire rolls over in a turn. and to monitor tire temp and pressure before and after driving. |
ny325895.00 |
