08-05-2020, 08:45 AM | #1 |
83
Rep 160
2020 X6 M50i with 22's confused about winter tire wheels
It seems like this has been talked about alot but I can't find anything specific that I can take to the bank.
I have an X6 M50i with the black 22" wheels running 275's up front and 315's in back. With winter approaching, I want to go to a 20" square setup with winter tires. According to wheelsize.com, the X6 M50i winter 20" square set up is as follows: Wheel 20 x 9 x 35mm offset 5x112 bolt pattern with a 66.6mm bore Tires are 275/45R20's. Here is my list of questions: Do I need to look for a rim that has an offset that is +/- 35mm by how much? Is it better to have more or less offset? Does positive offset position the wheel further out or in? If I can't get the offset I need, can I add a spacer? Is there a rule of thumb on how thick a spacer can be? I assume you will need longer lug bolts if you use a spacer? Will OEM lug bolts work with aftermarket wheels or do you need bolts specific to the rim you are purchasing? Do aftermarket TPMS sensors compatible? Thank you in advance for your help. Last edited by 812Superfast; 08-05-2020 at 05:01 PM.. |
08-05-2020, 03:17 PM | #2 |
1278
Rep 1,201
You're best bet is to go with a (used?) oem set of 20" wheels. However, if you must go aftermarket, stick to the width and offset/ET as best as possible.
Lower offset/ET = further away from the car. Higher offset = tucked under the car more. Definitely dont go with a higher offset..... unless you are going with a wider wheel. You don't want to negatively affect the stability of the car. You can vary up the offset a bit... no big deal. You MUST be sure the hub bore matches, and of course, the lug pattern. Yes, you can buy spacers. I wouldn't recommend anything over 20mm. Yes, you will need extended lug bolts. DO NOT CHEAP OUT ON CHINESE GARBAGE spacers or lugs. Buy the best you can (H&R). That is the LAST place on the car you want Chinese junk. Usually the oem lug bolts are a bit wide, and may scratch your aftermarket rims. It depends on the rims. TPM sensors.... are cheap. Just get an oem set on Ebay. Easy, no effort required. |
08-05-2020, 04:59 PM | #3 | |
4420
Rep 5,719
Drives: '24 iX50; '23 i4 M50
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
08-07-2020, 01:21 PM | #5 |
87
Rep 210
Drives: X5 M50i
I found a set of OEM take offs there are several on ebay for 1600-2000. I found a set of 20s for 1700 shipped!
Used the blizzak LM001 W speed rated as well... Now is a pretty good time before the snow flies:-) |
09-19-2020, 12:28 AM | #6 |
187
Rep 231
Subscribed. I'm in the same boat as you OP. Looking for aftermarket 20" winter wheels, but no wheel retailers want to confirm fitment or not.
Please let me know what you find out and vice versa. Unless I find them super cheap, I'd prefer to stay away from OEM. No reason, just personal preference. |
09-20-2020, 07:45 PM | #7 |
702
Rep 697
I couldn't find a set of 740Ms for around $2K, so I just placed an order for a set of 20x9 +35 Forgestar CF10 wheels that are flow formed. They ran me $2K shipped :-) They will clear the larger M sport brakes.
For tires, I will go with the highly rated Bridgestone Blizzak DMV2s! |
10-02-2020, 09:10 AM | #8 |
109
Rep 235
Do you guys have Oponeo in the USA. In Europe you just key in the G05 and they list all the aftermarket wheels that fit for either summer or winter set up. Once ordered they ring you also to discuss the order to make sure it fits exactly what you have. Full winter set ups from only £1500-3500. They also make sure the load rating is correct for the wheel.
