07-29-2020, 12:00 AM | #1 |
Rep 7
HELP!!! All cylinders misfiring after new headgasket and timing chain
*SOLVED*
I'm scratching my head over here. Can somebody please point me towards the right direction. I had timing chain failure on my n20 and I removed the cylinder head to make sure that valve didnt hit pistons not knowing that n20 engine are non-interference. After finishing the job, the engine has been misfiring on all cylinders and I cant seem to be able to fix that. No DTC codes other than misfire and camshaft limit position sensor really. Reset the engine adaptations on ista+ thinking that'll do something but made no difference. The car did sit in the garage for 2 years before it was fixed so I syphoned the old gas out the filler cap but I guess the 2nd side of the tank would still have some. I thought maybe old gas clogged the injectors but poured injector cleaner in and ran for 30min which made no different either. Really appreciate any input. TIA! SOLUTION: Found out that cyl 2 spark plug had a crack in the ceramic insulation. I replaced it and syarted the car and it stopped misfiring after revving a few times. Last edited by issabimmer; 10-02-2020 at 07:22 PM.. |
07-29-2020, 09:44 AM | #2 |
8245
Rep 16,089
Did you use the required special tools? https://www.newtis.info/tisv2/a/en/f...shaft/HipcnQuO
07-29-2020, 11:11 AM | #3 | |
Rep 7
10-05-2020, 12:40 PM | #4 | |
76
Rep 151
Thanks, Sorry saw that you solved it on the first post.
Passively looking for a F80 M3 Competition & Executive w/ manual trans in all colors but black. Prefer 2018 and Carbon Cloth seats.
