07-28-2020, 10:21 PM | #1 |
28
Rep 129
Rod bolts
I know a lot of people blow these things up. But would upgrading the rod bolts make the engine handle more power or is it more rods rod bolts pistons that all have to be upgraded to make more of that 350whp?
07-29-2020, 12:24 PM | #2 |
27
Rep 63
I do not think there has been enough data to say yes or no. I think upgrading the rod bolts would be a prudent step.
2015 320i
2006 330i 2004 545i 2001 M Roadster |
07-29-2020, 12:43 PM | #3 |
479
Rep 1,065
There is a lot of info in this thread. You'll need arp bots (possibly two sets) to get the bolts in and torqued correctly via ARP's specifications. I want to do the same but it looks as if it would be worth it to just put in an entire bottom end (pistons + rods + bearings + custom oil pan w/ baffles to avoid oil starvation)
https://f30.bimmerpost.com/forums/sh...ight=rod+bolts |
07-30-2020, 02:40 PM | #4 | ||
27
Rep 63
https://www.bimmerworld.com/Oil-Pan-...rive-Only.html
2015 320i
07-30-2020, 05:28 PM | #5 |
479
Rep 1,065
The rod bolts are for the torque increase at low rpms, the oil pan baffles are for taking long high speed sweeping turns which is where the n20 has issues.
I'm looking at the pan and can't see directly how this would change the oil starvation issue. Perhaps navardi would know more to compare this and his baffle inserts?
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
mgeller51.50 |
08-06-2020, 11:10 AM | #7 |
Not stock
474
Rep 614
Uro has been remanufacturing BMW plastic parts in cast aluminum for a long time. Common to replace the E36/E34 plastic thermotat housings on the M50 engines w/ aluminum "Uro" brand. Not really a great quality, decent, but not great. I guess it'd allow you to weld in baffles.
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
