2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning B58 uprated charge pipe help
      07-24-2020, 01:18 PM   #1
Si-M240i
137
Drives: M240i LCI
So many B58 charge pipe upgrade options. I'm told that replacing this will improve throttle response slightly and reduce turbo lag slightly. We know it's not going likely split below 26psi, so not really required as preventative maintenance but if you want water/meth injection it's a must.
So who has fitted which ones and can confirm any of this in a real world observation and which ones are the best quality and fit. Now the forge one seems to be £100 more than all it's rivals so let me know what you have and what you think?
M240i LCI (Mineral Grey):- M2 Door Mirrors, M2 Black Kidney Grills, Lower grille inserts, MP Exhaust, Dinan Carbon Fibre CAI, hot climate intake elbow
      07-25-2020, 12:13 AM   #2
helloelectro
174
Drives: 2018 BMW m240i
Snake oil.
Si-M240i136.50
      07-25-2020, 07:14 AM   #3
NISFAN
NISFAN's Avatar
3489
Drives: BMW M2
What he said
Avoid any with different diameter pipes and a silicone adapter. Which is all of them.
      07-25-2020, 07:33 AM   #4
Si-M240i
137
Drives: M240i LCI
Originally Posted by NISFAN View Post
Why is that?
      07-25-2020, 02:42 PM   #5
123Britt
289
Drives: 15 M235i AT
Maintenance Item
B58 could be different from the N55 crowd: however, over time, the plastic Charge Pipe can crack due to heat and pressure.
CP is just a more stout air duct that can take the pressure & heat.
Usually upgraded with a tune .
Don't see it as snake oil -- glad I have mine.
Have not heard the CP provides a performance gain other than it doesn't crack or blow off under elevated pressure.
The B58 could be different but N55 plastic CP's do fail.
Appreciate 2
Si-M240i136.50
Hekler29.00
      07-25-2020, 02:44 PM   #6
Si-M240i
137
Drives: M240i LCI
I'm not mapped but was thinking of upgrading. I assume it's a waste of money without a remap then?
      07-25-2020, 03:33 PM   #7
NISFAN
NISFAN's Avatar
3489
Drives: BMW M2
Why is that?
If you fit a short expansion adapter like most charge pipes use, they introduce turbulent flow, which hurts performance. The angle should be no more than 15 degree included.
      07-25-2020, 03:35 PM   #8
Si-M240i
137
Drives: M240i LCI
Why is that?
So oem is best I guess
      07-26-2020, 09:20 PM   #9
JD11937
130
Drives: 2017 M240xi
If you are staying stock turbo it's not needed. Everyone I know with an upgraded turbo has upgraded for piece of mind. I have the vrsf, not overly impressed with the quality but it works. FTP has a good reputation and I've used their other products which were perfect fit. Few others out there now but I have no experience with them.
Appreciate 2
Hekler29.00
Si-M240i136.50
      07-27-2020, 07:05 AM   #10
helloelectro
174
I was referring to the B58 which doesn't have the failure the the N55 is plagued with. Everything I've read and heard is that BMW fixed the CP issue with the release of the B58.
Appreciate 2
123Britt289.00
Si-M240i136.50
      08-20-2020, 07:02 AM   #11
sauceonside
31
Drives: 2017 240i MT
Found this post after originally researching BM3, seeing lots of charge pipe issue stories, and wondering if I will need to upgrade mine. But I too have a B58.
Is it safe to say that a BM3 stage 1 would not need an upgraded charge pipe to be reliable? (Not tracking, just spirited driving and long highway trips).
      08-20-2020, 10:08 AM   #12
helloelectro
174
It doesn't appear to be a b58 issue. I'm also just a lurking forum member so take it for what you will lol. But yeah basically all indications are it's a non issue for our cars
      08-21-2020, 07:47 PM   #13
RedDedFred
Drives: 2017 BMW M240i
I ran BM3 stage 1 on my B58 for a year before upgrading to stage 2 last week. I've been running stock charge pipes the whole time and have had no problems.
      08-23-2020, 05:54 PM   #14
HP Autosport
Supreme Allied Commander
3847
Drives: F80 M3
There is definitely an increase in throttle response with a well designed CP. Maybe even more noticeable on a tuned engine.
Si-M240i136.50
      08-23-2020, 07:26 PM   #15
dradernh
dradernh's Avatar
4413
Drives: 2017 M240i
Can you share your before/after dyno data with us?
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro;
GTechniq Crystal Serum Ultra Ceramic; Suntek PPF
      08-24-2020, 12:07 AM   #16
HP Autosport
3847
Drives: F80 M3
Never did mention we dyno the vehicle nor did we mention hp or tq increase.
dradernh4413.00
2addicts
