Bimmerpost
4 Series
Technical Topics B58 6-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications Turbo Transformer Boost Controller. Simple, Reliable & Fun!
      07-19-2020, 08:42 PM   #1
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
24025
Drives: 07-335/12-328/18-M4/21-M4CP
Talking Turbo Transformer Boost Controller. Simple, Reliable & Fun!
I had the chance today to try the Turbo Transformer in my car, and I'm very impressed!
It's a very simple piggyback with only two sensors to connect. It'll take a few minutes to install. One of its best features is Bluetooth capability that allows you to use the TT app to change maps and settings.
I took a few screenshots of the app,and I figured i would show you how it works.
Setup
  • Ignition on , engine OFF
  • Open the Turbo transformer Bluetooth app
  • Select connect
  • Click on settings, then select Zero to calibrate the unit (you only need to do this step once. No need to calibrate the unit every time you turn on the car)
Base PSI:
This is the PSI level at which the tuner is active. when your boost is below this PSI, the unit is not active and the car is running at stock power
Delta PSI:
This is the maximum amount of PSI the unit will be adding to stock. Its set to +2 PSI by default but can be increased to +4 PSI (please use with caution)
Slope (Rate):
  • This value dictates how fast you want the unit to add boost
  • Slower Boost increase will result in a smoother power delivery
  • Faster boost increase will result in maximum power and responsiveness
Graph:
  • The X axis is your stock boost. The Y axis is what the ECU is reading
  • The grey line is stock power (X and Y will always be equal)
  • The white line is your current map
  • The red line is your custom map
Power Modes
  • Power Default
  • Max Eco
  • Hybrid
  • Custom
Power Default
  • The default map is +2 PSI
  • When X is 16 PSI, Y is 14. This means when you car is pushing 16 PSI, your ECU is reading 14 PSI. It will add 2 more PSI to get to the 16 PSI target boost resulting in an actual PSI of 18.
  • Note: the tuner is not active till boost reaches a set PSI value (Base PSI). In this case its 11 PSI
Max Eco
  • This map is the opposite of default power
  • The ECU read value is higher than actual boost, which results in the ECU lowering the PSI
Hybrid
  • This is a very unique and interesting map.
  • Its on ECO settings when boost is lower than your base PSI & on Default Power settings once boost exceeds your base PSI
Custom
  • In this map, you get to control the base PSI, delta PSI and slop rate
  • Please use with caution
https://x-ph.com/sale/
Phone number 702-494-9435
      07-24-2020, 02:01 PM   #2
Mr.G20 M340
Mr.G20 M340's Avatar
221
Drives: 2020 Portimao Blue M340-x
So is this for cars that are tuned already or is this sort of a tune on its own or something?
Instagram: Bmw_Captivate
2020 Portimao Blue M340 X Drive and adaptive suspension.
Mods: custom exhaust, VRSF Catted DP, Injen intake and Chargepipe.
      07-24-2020, 02:14 PM   #3
chenry
2355
Drives: BMWs
It is not for cars that are already tuned - it is a basic piggyback offering. It is similiar to a JB+ and a Dinantronics sport tuner albeit with what looks like a very cool interface
      07-27-2020, 10:23 AM   #4
mike@x-ph.com
24025
Most customers will use it on a stock car; that being said you can stack it with your flash tune for more boost.
If you are using it with another tune, we strongly recommend you datalog and make sure your car is handling the extra boost well
      07-27-2020, 10:25 AM   #5
chenry
2355
Drives: BMWs
I stand corrected thanks for the clarification Mike!
      07-27-2020, 10:53 AM   #6
mike@x-ph.com
24025
      08-13-2020, 09:07 AM   #7
mike@x-ph.com
24025
      08-20-2020, 01:42 PM   #8
mike@x-ph.com
24025
      08-27-2020, 11:10 AM   #9
mike@x-ph.com
24025
      08-27-2020, 05:53 PM   #10
bSwiazzy
201
Drives: 2021 X3M
how does this compare to stage 2 JB4?
2015 Honda Civic Si // FBO + Hondata // Retired
2017 340i // FBO + BM3 // Retired
2020 M340i // Stage 2 // Retired
2021 X3M // RGSport Midpipe + MSS + RaceChipGTS // Retired
2016 Rav4
      08-28-2020, 11:26 AM   #11
mike@x-ph.com
24025
The Jb4 is a lot more advanced with a ton of features, including data logging, safety failsafes, boost by gear, boost by RPM, etc...
The Turbo Transformer is a simple boost control with cool features and Bluetooth capabilities at a great price.
Different target customers in my opinion
      09-10-2020, 04:24 PM   #12
bSwiazzy
201
Drives: 2021 X3M
have you heard of any issues on the JB4 on the m340i?
its the same jb4 tune you would use on any B58 corrrect mike?
so like 2018 340i jb4 is the same as the m340i jb4?
2016 Rav4
      09-11-2020, 09:03 AM   #13
mike@x-ph.com
24025
Its the same hardware but I think its a different software for the G chassis. Please confirm with BMS direct.
      09-11-2020, 10:34 AM   #14
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
FWIW I’m running a JB4 in my G20 330i that was previously used in a F30 340i. Works perfectly. No issues.
You should have no issues running a JB4 used in a 340i in your M340i since it’s the same box for the B46/48/58 engines.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      09-11-2020, 11:21 AM   #15
bSwiazzy
201
Drives: 2021 X3M
goodlooks
2016 Rav4
      09-15-2020, 08:32 AM   #16
mike@x-ph.com
24025
Did you check with BMS if the software is the same?
      09-15-2020, 12:59 PM   #17
VipinLJ
Petrolhead
VipinLJ's Avatar
1942
Yes. Mailed them and they said it was fine. Even sent them logs and they said everything looked perfect
Current:
      09-16-2020, 09:41 AM   #18
mike@x-ph.com
24025
Search this Thread:
Advanced Search
g20
