07-19-2020, 04:14 PM | #1 |
BimmerPost Supporting Vendor
24201
Rep 190,807
Active Autowerke B48 Catted Downpipe *** NO CEL GUARANTEE ***
Active Autowerke BMW B48 Catted Downpipe BMW introduced a new valvetronic, single turbo version of its direct-injection engine for the later F-Chassis models beginning in 2016. The Active Autowerke B48 downpipe for the 230i, 330i and 430i helps unleash some of the potential that is restricted by the OEM downpipe. Turbochargers are powered by spent exhaust gases created during the combustion process. The quicker these gases are evacuated, the better. Unfortunately, the factory down pipe in the B48 is quite restrictive, which results in slower exhaust gases and slower turbo spool. The Active Autowerke F-Chassis B48 Signature down pipe utilizes 3 inch diameter stainless steel piping in order to provide more power, quicker spool, and extreme durability. We've incorporated a stainless flex joint and then tapers down to 70mm to meet the OEM exhaust system. We never drop the diameter less than the stock diameter of 70mm. This variant includes a 4.5" high flow GESI catalytic converter that will NOT produce a CEL! The GESi® G-Sport Ultra High Output Catalytic Converter features full 304 stainless steel construction, including the substrate. GESi® UHO-Series Catalytic Converters are EPA certified in 49 states and fully OBD2 compliant, perfect for use on 1996 and newer vehicles. GESi® proprietary precious metal loading technology ensures greatly reduced emissions, eliminating most "Check Engine Lights". These high flow catalytic converters outperform stock converters and provide a reliable solution to the most common catalytic converter problems. The GESi® UHO-Series Catalytic Converters are rated for engines putting out between 500 and 850 horsepower while maintaining a high flow capacity. The reduced back-pressure from this high flow catalytic converter will allow you to maximize your engines horsepower without the harmful emissions. Say goodbye to Check Engine Lights and failed emissions tests! Please Note: These catalytic converters are not legal for use on vehicles registered in the state of California as a result of California Vehicle Code Section 27156 and 38391. Features:
Made in Miami, Florida Covered by 5 Year / 50,000 Mile Warranty (on shell and tube ends) Active Autowerke B48 Downpipe Benefits The speed of a turbo’s impeller wheel is limited by exhaust back pressure. A larger down pipe relieves some of this pressure, resulting in quicker and more efficient spool. With Active Autowerke’s downpipe, your B48 can rev quicker, and deliver more horsepower and torque. Minimizing back pressure while retaining daily drive-ability was the goal of our B48 downpipe. Owners can now upgrade to a product that is affordable, reliable, and easy to install. After months of research and development, our engineers settled on a 3 inch diameter pipe which utilizes the least number of bends possible. The large volume helps the turbo spool as quickly as possible by eliminating back pressure during spool up. We are ushering in a new era in performance where we maintain air control standards without significant losses in power by using the GESI super high output catalytic converter in our signature downpipe. Constructed entirely from 304 stainless steel with 1.5MM wall thickness, we are confident that you’ll be pleased with how robust and durable this down pipe is. Trouble-free installation and a long lifespan ensure that you’ll enjoy many miles of performance with your B48!
08-13-2020, 09:14 AM | #2 |
485
Rep 226
Drives: G81 M3T / X5 F15 30d
How much?
Proud owner of G81 M3 Touring
08-13-2020, 10:02 AM | #3 |
24201
Rep 190,807
IanW555484.50 |
08-13-2020, 10:08 AM | #4 |
485
Rep 226
Thanks Mike, how do you rate this against the same from Evolution Racewerks?
08-13-2020, 02:07 PM | #5 |
#im_2_Fr3sh
30
Rep 247
Do they make one for n26 engine? 100 guarantee no cel???
2014 428i xDrive F32 | Injen Cai | Er Intercooler | Er Chargepipe | Er Tic Pipe | Er Catless Downpipe | Bm3 - Cary Jordan tuned 93 oct | Gfb Dv | Ngk L/I Spark Plugs | Cf High Kick Trunk Spoiler v1 | Black Grilles | 35% Suntek Tints | Michelin pss4 | Awe Quad Exhaust w/ Resonated Midpipe | Interior Mods | Mst Turbo Inlet | Pure Stage 2 Turbo | Arp rod bolts | Fuel-it Stage 2 Lpfp | Braum Elite x seats | Mishimoto Oil-catch can |
08-13-2020, 05:09 PM | #6 |
520
Rep 1,173
I think the stone exhaust has no CEL guarantee version for N20 at least. I believe it's on x-ph website.
2020 X3 M40i
2015 328i - Sold @ 104,000 miles |
08-14-2020, 09:23 AM | #7 | |
24201
Rep 190,807
+1 (N20 only)
IanW555484.50 |
08-14-2020, 08:48 PM | #8 |
#im_2_Fr3sh
30
Rep 247
Aww no n26 love
08-15-2020, 01:23 PM | #9 |
24201
Rep 190,807
08-17-2020, 06:20 PM | #11 |
24201
Rep 190,807
08-18-2020, 09:54 AM | #13 |
24201
Rep 190,807
Not unless the issue was caused by the coating
