2010 CIC gone bad and looking for replacement
07-12-2020, 11:12 AM | #1 |
Rep 71
Drives: 2010 335i X-Drive (E90) (sold)
I haven't been on here for nearly a decade and my CIC recently went bottoms up. It boots to the BMW screen and resets constantly. Since there is no warranty, I went ahead and took it apart to see if there was anything obvious (loose connections, visible cracks, etc) but there is nothing visible that I can detect so I am assuming that one of the chips are bad on the main board.
I looked around for CIC repair and they mostly seem to be outside of the U.S.. So, I assume, I need to replace the unit. I would like to replace it with something better since I've seen the newer BMWs have great functions like Bluetooth audio (probably gapless playback) and other better features my CIC system does not have. I've seen threads about retrofitting CICs, but I already have the CIC so I don't think those are for me. Are there retrofitting options for the next generation? Otherwise, I will just have to ask the dealer to code me a new one for big $$$$. I'm open to any suggestions if you have them. Thanks. |
07-12-2020, 03:21 PM | #3 |
Rep 71
Thanks for your response. That is the first thing I did and the behavior did not change - so I am thinking it may actually be an IDE controller issue, which I believe is on one of the main boards.I also checked it in linux - the boot sector and partition table seem to be OK.
07-14-2020, 07:43 AM | #4 |
Rep 71
I found this place, https://www.bimmerretrofit.com/, and will likely get the NBT EVO kit.
But I found this thread, which gave me pause: https://www.e90post.com/forums/showp...4&postcount=10 Last edited by DeFKnoL; 07-14-2020 at 10:18 AM.. |
07-26-2020, 06:51 PM | #5 | |
1458
Rep 1,912
07-28-2020, 02:20 PM | #6 | |
109
Rep 235
I have purchased every related module in the trunk (thought I may have spilled water back there) trying to fix it. Let me know if you want to try any of them out as they are collecting dust. |
07-28-2020, 04:36 PM | #7 | |
Rep 10
I did a CCC to CIC retrofit myself including coding. It's really not all that hard. Replacing your CIC with a new one should be easier since all the wiring is already there. I highly recommend following FaxData's Thread on how to code a CIC unit and not have to use an emulator. https://www.e90post.com/forums/showthread.php?t=1649066 |
Tags |
cic and idrive |
