TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > N52 rythmic thumping sound at idle
      07-12-2020, 12:08 AM   #1
Yamadogggy
Drives: 2011 BMW 328xi
Its the wobble/thud noise kind of low frequency. Kind of sounds like something wobbling if that makes sense. Consistent thumping fast pace. Kind of like a slight knocking but not really a knock at the same time. Already changed belt and tensioner and idler pulley. I can hear it in cabin too but camera doesn't really pick it up. Any ideas help. Thanks.
      07-12-2020, 01:13 AM   #2
AoS810
AoS810's Avatar
97
Drives: 2008 E90 N51, 2011 E91 N52
I can't speak for the sound, but if you already replaced your tensioner then the belt movement does not look right. The belt should not be moving back and forth like that on the tensioner.
      07-12-2020, 01:18 AM   #3
Yamadogggy
old video, I've changed belt fixed that up. The 1st new belt I installed walked like that I just re used the video since sound is still present.
      07-12-2020, 04:02 AM   #4
Phil325i
Phil325i's Avatar
616
Drives: E92 325i MSport Coupe
The deep rythmic noise could just be your HPFP. They do tend to make a rythmic thump...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
      07-12-2020, 09:00 AM   #5
Yamadogggy
Its a 328
      07-12-2020, 11:50 AM   #6
Phil325i
Phil325i's Avatar
616
Originally Posted by Yamadogggy View Post
Its a 328
Erm...yeah so? It's an N52 so it still has a HPFP, doesn't it?
      07-12-2020, 05:19 PM   #7
bluewater328
626
Drives: 2011 bluewater 328i LCI sedan
Nope. Only for Direct-injection application (N54/N55)
AoS81097.00
      07-12-2020, 06:23 PM   #8
AoS810
AoS810's Avatar
97
Have you tried scanning the car for codes to see if anything engine related pops up?
      07-12-2020, 09:52 PM   #9
Yamadogggy
Don't have a tool or scanner. What would you recommend? The dealership offered me what I owe on it i was honestly considering trading er in on a2017 CPO 320i with 25k miles. I would have a lower interest rate as my credit really jumped since I got this one. It almost sounds pulley related. I'll run with belt off and see if any difference.
      07-13-2020, 08:39 AM   #10
Volasko
Volasko's Avatar
705
Drives: 06 330i E90, 18 530xe G30
I would take the car for a rip to clear up that ticking noise and see if you can take a video. I can't hear what you're talking about and sounds pretty normal to me. Does it still drive fine? If so I wouldn't worry about it too much.
      07-13-2020, 09:16 AM   #11
Yamadogggy
Drives fine. The noise sounds like helicopter blades if that makes sense. You can hear it pretty clear in that video if you ignore lifter tick
      07-13-2020, 09:24 AM   #12
Volasko
Volasko's Avatar
705
Ahh I hear it now, just for curiosity sake I fired up my car (it was cold and sat all night) to see if I could hear something similar. Interestingly enough I could hear the same rhythmic sound once I started listening for it. Now I have 285k km's on my car and it still pulls like a champ, its main use now is track days and the odd sunny day boot which it does very well. Does that mean this sound is normal? Who knows, but I'm leaning more towards not worrying about it tbh.
      07-13-2020, 09:49 AM   #13
Yamadogggy
Makes me feel better. If I recall right with a mech stethoscope on my plastic engine cover im pretty sure it comes from there. Probably just our noisy ass valve train hahah
      07-13-2020, 12:36 PM   #14
Yamadogggy
Just for the sake of not starting another thread. This noise has been worrying as well.
Most prominent in right side/passenger wheel well. Thinking water pump? Hasn't been replaced yet to my knowledge car has 76k.
      07-13-2020, 12:41 PM   #15
Yamadogggy
My ac pulley is bypassed as well to eliminate that as a source
      07-13-2020, 03:45 PM   #16
AoS810
AoS810's Avatar
97
I'm still on the original water pump at 157,500 miles. I've read that you'll actually get codes for speed deviations etc for the water pump once it starts to crap itself. Another reason to get a scanner if you'll be using it for BMW! I have a Foxwell NT510 that I've been pretty happy with, the only thing it let me down on so far was activating the DISAs on a 3-stage intake manifold.
      07-13-2020, 09:38 PM   #17
bluewater328
626
You can "potentially" get some. A lot of times its so close to failure you barely have a chance to see. Those codes won't actually trip any lights that show on your dash until its already at the yellow/red warning/failure coolant phase. You'd have to be checking the codes arbitrarily and catch it. You probably have a better chance with a 328i vs 335i but that's more conjecture than anything else.
Tags
engine knock, n52 thump, thud, thump
