BMW X5
      07-09-2020, 03:00 PM   #1
The Kid Dav
England
Drives: BMW X5 G05
Wheel spacers on X5 G05 with 22" wheels
Hi
Has anyone put wheel spacers of X5 G05 with 22s?
I have no experience with spacers and I'm trying to figure out what spacing and what brand.
Thanks
      07-09-2020, 04:08 PM   #2
UltraDave
UltraDave's Avatar
127
Drives: 2020 BMW X5 M50i
Originally Posted by The Kid Dav View Post
Hi
Thanks
Yes, 12mm front and 15mm rear is conservative and 15mm/20mm would be aggressive.
      07-09-2020, 04:34 PM   #3
The Kid Dav
England
Drives: BMW X5 G05
Hi
Thanks
Thanks. Any idea where to buy top quality ones?
      07-09-2020, 05:53 PM   #4
CarMan77
CarMan77's Avatar
425
Drives: 2021 X7 M50i, 2021 Porsche Cay
Check out this thread
https://www.bimmerpost.com/forums/sh...php?p=24643970
The OP Ben at RG Sport is highly respected.
Appreciate 2
      07-09-2020, 08:36 PM   #5
UltraDave
UltraDave's Avatar
127
https://ind-distribution.com/collections/x5-g05
I have been very happy with the quality and service with these guys.
      07-10-2020, 07:49 PM   #6
MaCaY
X5 M50i
MaCaY's Avatar
110
Drives: 2020 X5 M50i
I got 12,15,18,20mm. Spend some time with different set ups end up with 12mm front and 18mm in the back from IND.
15,20 set up looks perfect if you lowered, loading hight if you have air suspension.
12,18 looks good in comfort mode and perfect in sport mode( i drive only in sport)
If you dont have air suspension or drive only in comfort get 12,15mm.
      07-11-2020, 02:55 AM   #7
The Kid Dav
England
Drives: BMW X5 G05
Thanks . Yeh I will have air suspension so 12/18 sounds like a good middle ground. Does the kit from IND use the longer wheel nut (connect wheel and spacer in one) or it does the spacer fix using separate nuts? I've read a few times that the longer nut style is weaker and not as good
xbimmers
