Bimmerpost
4 Series
Technical Topics Wheels and Tires M340i - Replace my run flats with non-run flats?
      07-07-2020, 08:22 PM   #1
Simsimma7
Simsimma7's Avatar
17
Drives: M340i XDrive
Hi everyone, my m340 I came with Cinturato run flat tires. I’ve noticed that the two front tires have multiple air bubbles on the side walls!!! So I’m thinking I should replace them asap.
In your experience, do you think it’s best to replace all of them with non-runflat tires instead? Are those any better? Which brand/model would you recommend?
Thanks in advance!
      07-07-2020, 08:45 PM   #2
Dmejia91
58
Drives: 14 F30 335 xdrive M Sport
Thanks in advance!
Literally happened to me as well smh, thinking about swapping out to non run flats since I'm going stage 2. Will have to eventually purchase tires within the 3 year lease
      07-07-2020, 08:54 PM   #3
Simsimma7
Simsimma7's Avatar
17
Forgot to mention...I only have 16K miles on them... so disappointing.
      07-15-2020, 10:49 AM   #4
Sheezus
Sheezus's Avatar
Drives: BMW M340i
Definitely change them. Run flats makes the ride uneasy on bumps and I have changed mine to non run flats and I like them. Only downside is not having a spare tire but I have a pump in my car just in case and if I do run into a flat tire, I may need to keep pumping the tire till I reach a tire shop.
      07-15-2020, 11:42 AM   #5
TTG
TTG's Avatar
932
Drives: M340
I ordered the car with non-flats + a spare and couldn't have been happier. Definitively get rid of the runflats.
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
      07-15-2020, 10:12 PM   #6
Simsimma7
Simsimma7's Avatar
17
Thanks guys! Very helpful advice. I’m bringing it tomorrow so will change them for non run-flats.
      07-16-2020, 07:06 AM   #7
del82
102
Drives: BMW M340i xdrive
Just on this - I've had my M340i X in for some work this AM and they did a complimentary health check - check tyres, suspension, brakes etc.
It currently has runcraps on from new. Front tyres 5mm. The rears: 3mm. So lost 50% of tread. I've done 4200 miles. No track days, normal road driving.
My MPSS4S on my previous M140i which was rear drive only lasted 12000 and I did like a spirited drive in that.
Madness although a food excuse to get rid of the runcraps soon!
Current: 2020 M340i
Past: M140i, Z4 35is
      07-16-2020, 06:52 PM   #8
Dmejia91
58
Which tires would you guys change them to?
Continentals, hankook, Michelin, or etc.
      07-17-2020, 08:36 AM   #9
Sheezus
Sheezus's Avatar
Drives: BMW M340i
It depends if you want summer, all season, or winter tires. For all season, I went with Michelin Pilot Sport A/S 3 +. Very good tires.
      07-17-2020, 08:43 AM   #10
Dmejia91
58
Yeah probably all seasons, will look into them
      03-18-2024, 05:35 PM   #11
340guy
340guy's Avatar
Germany
Drives: 2023 M340i xdrive
Late to the party here and new to the forum… I have run flats on the car and it was the only option. But I spec’d the spare tire with the intent of getting non-run flats. My only concern is bent rims. Has anyone had an issue with this? The autobahn is great but the secondary roads in Germany are terrible. Also, any recommendations on tires? I plan on swapping winter rims to summer tires and I’ve always gone for Michelin but I’m considering Vredestein.
      03-23-2024, 01:47 PM   #12
GA/\/\/\/\A_CT
215
Drives: ‘20 m340ix
I just replaced my OEM cinturato with a non-run-flat set of Continental DWS06 in slightly larger size (235/40/19) and am very impressed.
The car runs more smoothly over rough pavement and grips better, too.
      Yesterday, 06:16 AM   #13
tgrundke
313
Drives: '23 M340xi; '16 GTI Autobahn
2023 M340  [10.00]
I'm running Vredestein winters on my '16 GTI and am really impressed with them. Came from a set of Michelin Alpin's prior and while I liked the Michelins, the Vredestein price point and performance are a much better value.
I've got non-runflats on my '23 M340 and am going to be swapping them for Conti DWS06+s later this year.
      Yesterday, 08:24 AM   #14
prostcfc
prostcfc's Avatar
51
Drives: 2020 BMW M340i
For those that ditched run-flats and don't have a spare, are you relying on roadside service, or did you get a plug set/jack/air pump (or find an aftermarket spare)?
      Yesterday, 09:26 AM   #15
AM340iMiami
AM340iMiami's Avatar
209
I always keep a tire plug kit and a portable tire inflator off Amazon in case of emergency in the trunk.
      Yesterday, 02:45 PM   #16
vi3tr8cer
Drives: 2020 G20 330i xDrive
I got my tires through Tire Rack, which came with 2 years of roadside assistance for free.
Tags
m340i
Search this Thread:
Advanced Search
g20
