07-07-2020, 06:17 PM | #1 |
97
Rep 123
Drives: 2020 BMW M340i
Coding Comfort Plus on M340i
Hi folks,
I wasn't able to find any clear instructions on how to enable comfort plus (comfort+) on m340i including the setting in in ECO Individual setting. It took some fiddling but found it on my own. Here's what you need to do. It enables Comfort Plus when you hit the comfort button, shows in the gauge cluster as well as idrive screen. You can also set Comfort plus in Eco Pro Individual in both steering and suspension. I have Adaptive M suspension (2VF), I don't know if it makes any difference if you don't have 2VF. FWIW, driving wise, suspensions definitely feels a lot more softer. I wasn't able to feel a great deal on steering with Comfort Plus. enjoy! Code:
BDC_Body3 > CAFD_7083 > ComfortWorldMode1 -> Change to: ComfortPlus HU_MGU > CAFD_3E52 > FES_COMFORT_PLUS -> Change to: Active HU_MGU > CAFD_3E52 > ECO_CONF_STEERING_COMFPLUS -> Change to: Active HU_MGU > CAFD_3E52 > ECO_CONF_ATTENUATION_COMFPLUS -> Change to: Active
2020 M340i RWD | C3Z | MAPQ | ZDA | ZDY | ZPK | ZPP | 1CR | 1PU | 688 | 6NW | 2VF | 316 | 4UR
Visit my Instagram |
07-07-2020, 07:09 PM | #2 | |
45
Rep 59
Some instructions for Bimmercode: BDC_Body3 > Expert Mode > Search "ComfortWorldMode1" -> Change to: ComfortPlus HU_MGU > Expert Mode > Search "FES_COMFORT_PLUS" -> Change to: Active HU_MGU > Expert Mode > Search "ECO_CONF_STEERING_COMFPLUS" -> Change to: Active HU_MGU > Expert Mode > Search "ECO_CONF_ATTENUATION_COMFPLUS" -> Change to: Active |
07-07-2020, 07:46 PM | #3 |
Petrolhead
1942
Rep 3,521
What do the last two settings do? Does the second last one make the steering even lighter than when it is in comfort?
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige Last edited by VipinLJ; 07-08-2020 at 12:08 AM.. |
07-07-2020, 10:08 PM | #4 |
345
Rep 751
https://github.com/packetpilot/bmw-f...s/jokinawa.xml
Search comfort plus on the page, you'll see that cheat codes already exist for all these settings and more comfort plus changes Last edited by siegester; 07-08-2020 at 04:53 PM.. |
Marco115912.00 |
07-08-2020, 01:10 AM | #5 | |
20
Rep 62
07-08-2020, 04:53 PM | #6 |
345
Rep 751
07-08-2020, 10:55 PM | #7 |
78
Rep 107
Many thanks for the instructions.
Swagasaurus-R3X44.50 fstephano7.50 |
07-14-2020, 03:51 AM | #8 | |
38
Rep 60
Also how can I get this activated on my car as I'm. new to coding and never attempted before. Mine is a Sep 19 build. Thanks! |
09-13-2020, 06:28 AM | #9 | |
13
Rep 171
09-13-2020, 12:17 PM | #10 |
345
Rep 751
FYI, Jokinowa has had this in his cheats for a year or so.
https://github.com/packetpilot/bmw-f...s/jokinawa.xml |
09-16-2020, 11:18 PM | #11 |
The Wolf
247
Rep 987
Drives: stuff
When you do this do you get comfort and comfort plus?
09-19-2020, 01:26 PM | #12 |
548
Rep 1,161
09-20-2020, 02:22 PM | #13 | |
The Wolf
247
Rep 987
Drives: stuff
Can't find these in expert mode in bimmercode on my us m340i, no bdc3 either... Hmm 3/2020 software |
09-21-2020, 06:49 AM | #14 |
658
Rep 1,479
Drives: 2020 M340Xi (G20)
ls3c6 ,
When you use Bimmercode, select a module, then in upper right corner is a slide switch that is Expert mode. Also, if I recall, BDC is called Body Controller, or something like that. When in Expert mode, you can search for the Specific function, but you have to be in correct section (a 4 digit number & name) Hope that helps!
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
09-21-2020, 06:47 PM | #15 | |
The Wolf
247
Rep 987
Drives: stuff
09-22-2020, 09:19 AM | #16 | |
658
Rep 1,479
Here you go: HU_MGU3: 3008 FES FesComfort_Plus from 00 to 01 3008 FES Eco_Conf_Attenuation_ComfPlus from 00 to 01 3008 FES Eco_Conf_Steering_ComfPlus from 00 to 01 BDC_BODY3: 3221 PfFesMaster FesComfortWorldMode1 from 00 to 05 3221 PfFesMaster FesPiaDefaultEcoWorldMode from 07 to 09 3221 PfFesMaster FesPiaDefaultComfortWorldMode from 04 to 05 I used Bimmercode in Expert Mode with ENet cable & LAN to USB-C adapter connected to my Samsung S8 to do that & it worked fine Hope that helps!
Al
euro_syd1.50 |
12-30-2021, 05:33 PM | #18 | |
316
Rep 691
What do these two added codings do exactly? The OP didnt mention these.
3221 PfFesMaster FesPiaDefaultEcoWorldMode from 07 to 09 3221 PfFesMaster FesPiaDefaultComfortWorldMode from 04 to 05 Quote:
12-31-2021, 05:36 AM | #19 | ||
658
Rep 1,479
Honestly, not sure, BUT I do know that the list of codes I provided does work -- can't say I use it much though
Al
gnolivos316.00 |
03-20-2022, 05:26 PM | #20 | |
3082
Rep 381
Drives: '21 330i xDrive
Fwiw after coding comfort plus only as the driving mode and on the iDrive, I feel like the car became a bit more responsive. It feels like the perfect balance between sport and comfort and imho kinda brought the car a bit more alive. Sounds identical to Comfort; I can still hear the turbo etc, and steering is the same as comfort if not sliiiightly tighter but that sliiiightness might just be placebo from the car feeling more responsive. If you've coded it you can see that it says "extra comfortable setting", so I think the attenuation and steering values changed would mean a quieter car with more flaccid steering. |
03-24-2022, 10:25 PM | #21 |
3729
Rep 4,083
the steering is much lighter, and by some margin. i tried it yesterday and switched between comfort and comfort plus.
however the car is not as pointy, it's like it also has a lazier turn circle but this i can't confirm. haven't had a chance to switch back and forth to run over bumps to test the magnitude of softer suspension - will do that at some stage and report. |
05-18-2022, 12:27 PM | #22 | |
101
Rep 307
I coded ComfortPlus but left out the steering and the attenuation |
