What's the point of the kick-down button on the gas pedal?
07-07-2020, 12:30 PM | #1 |
2002
Rep 3,731
.....there is already a Throttle pedal position sensor.....the DME knows how much you are pressing the gas pedal down. The transmission will downshift already based on throttle position and load, even if you don't hit the kick down button....so why add a separate kick-down button? Why have it? I'm assuming there is a point to it......buy why do you need it if the DME can already monitor pedal position?
Thanks!! Just trying to learn something.....
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
07-07-2020, 09:54 PM | #2 |
24
Rep 105
So the driver has control over going between WOT and WOT after dropping down a gear?
I could be wrong though, I bought a manual transmission 335 because I'm a big boy now. |
07-08-2020, 06:24 AM | #3 |
641
Rep 1,245
kickdown requests the absolute lowest gear possible, a gear thats not always 'needed' to complete the torque request the pedal is asking for
its giving the driver a minor amount more control over just how much of a downshift they want
2009 335i xDrive AT / 177k+ miles
PSP 750ic / Fuel-It! Stage 1 / BMS CP / Sutphin Tuning / RFP E50 11.61 @ 117.5 New setup; Covid 19Ts on RFP 93 + ARM inlets, dp, VTT cp and PSP outlets |
07-08-2020, 06:53 AM | #4 |
2002
Rep 3,731
....but why do that with a separate button? Why not just have the DME do the same kickdown function when it sees 98% throttle pedal input (or whatever that last little bit of pedal travel is)? Is it to give you the actual "feel" of hitting the button? I guess that would kind of make sense? ....what way you know exactly where that point is.....whereas if you just used pedal travel input, you might not have a good feel of where that point is?
07-08-2020, 07:00 AM | #5 |
641
Rep 1,245
yes. to give the driver a little bit more control.
the dme is already able to fulfill the torque request without another downshift, but people like the feeling of it banging straight into the high revs instead of using a higher gear and torque to make it happen dont like it, turn it off. mine is, has been for ages because xhp custom rev limits wont work without it deactivated. only notice anything in drive. sport works as if the button is on still because of different logic built in.
07-08-2020, 07:26 AM | #6 | |
2002
Rep 3,731
