F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Where's the AUC sensor in an F30 328i
GetBMWParts
      07-06-2020, 12:12 PM   #1
johnsonlwu
17
Drives: F30328i x 2 (yes, 2)
2020 bmw 840i  [0.00]
Got an error saying it's shorted to ground.
Is it closer to intake or somewhere close to cabin filter?
Any help appreciated.
      07-06-2020, 03:37 PM   #2
HighlandPete
6659
Drives: BMW F11 535i Touring
https://www.newtis.info/tisv2/a/en/f...trols/GzpUNuHR
      05-13-2021, 10:50 AM   #3
Axis527
Former WRX Geek
12
Drives: 2014 335xi Sport Line
So I just replaced mine in a 2015 F30 335xi. Since newtis has been shut down I couldn’t find the location anywhere. For anyone that needs to replace the AUC sensor in the F30 chassis, it isn’t in the footwell. You’ll find it in the engine bay, under the passenger side cowl (battery terminal cover) up by the windshield. It twists out like a bulb. Super easy to replace once you actually find it.
      03-06-2023, 10:32 PM   #4
cgraner
Drives: 2014 BMW 335i, 1998 BMW M3
804397 AUC-Sensor: Short circuit to ground
https://bmwfault.codes/
Put in 804397 and your engine code
804397 Automatic air recirculation control (AUC) sensor: Short circuit to ground fem_20 Front electronic module
804397 Automatic air recirculation control (AUC) sensor: Short circuit to ground bdc Body Domain Controller
804397 Automatic air recirculation control (AUC) sensor: Short circuit to ground bdc_g11 Body Domain Controller
https://bmwfault.codes/XMLDiagView?d...MAMwA1ADAANAA=
Fault Code Description
This fault code is entered if a short circuit to ground was detected at the automatic air recirculation control sensor.
Fault Code Conditions
General Conditions Supply voltage: 9 V - 16 V
Terminal Condition Terminal 30B on
Driving Conditions
Fault Time Condition
This fault is registered in the fault memory if it is continuously present for a period of at least 2 s.
Service Plan
Check the wiring between the AUC sensor and front electronic module (FEM) for damage and repair, if applicable. If the lines are OK, check the AUC input of the front electronic module (FEM) short circuit to ground. If a short circuit is detected, replace the front electronic module (FEM).If a short circuit is not detected, replace the AUC sensor.
      03-06-2023, 10:33 PM   #5
cgraner
https://www.fcpeuro.com/products/bmw...mw-64119240180
BMW AUC Climate Control Sensor - Genuine BMW 64119240180
Product Information
Controls your BMW HVAC recirculation system by controlling the recirculation flaps
This clever little sensor detects the levels of oxidizable gasses flowing through the engine bay. When a specific threshold is reached, the HVAC recirculation flap closes for a specific time after the noxious gasses are no longer present.
Only for BMW's equipped with Automatic air conditioning (S534A)
f30post
